Hi Folks
I found discourse solved plugin quite useful in my forum. Then I tried to add an Unsolved button to top menu. Since it was not straight forward I adopted this solution and altered it a bit.
That works great, if you want to only display the buttons on certain categories then you can do some fairly simple logic to check the category name. I also filter out “closed” topics for my “unsolved” button.
This is what I use:
<script>
Discourse.ExternalNavItem = Discourse.NavItem.extend({
href : function() {
return this.get('href');
}.property('href'),
I18n.translations.en.js.filters.Completed = { title: "Completed", help: "Topics that have been marked as solved" };
I18n.translations.en.js.filters.Outstanding = { title: "Outstanding", help: "Topics that are not yet marked as solved" };
Discourse.NavItem.reopenClass({
buildList : function(category, args) {
var list = this._super(category, args);
if(!category) {
//Don't display anything
}else if(category.slug==='support') {
list.push(Discourse.NavItem.create({href: '/c/support?solved=yes', name: "Completed"}));
list.push(Discourse.NavItem.create({href: '/c/support?solved=no&status=open', name: "Outstanding"}));
}else if(category.slug==='jobs') {
list.push(Discourse.NavItem.create({href: '/c/jobs?solved=yes', name: "Completed"}));
list.push(Discourse.NavItem.create({href: '/c/jobs?solved=no&status=open', name: "Outstanding"}));
return list;
</script>
I’m having a little issue with combining those two. What should I have if I want both only a certain particular category and subcategory to show Solved/Unsolved?
Hola, estoy verificando si esto se convirtió en un componente de tema que simplemente no puedo encontrar. No he visto nada explícito, pero las instrucciones anteriores parecen adecuadas para agregar un botón de menú superior respetando las subcategorías en las últimas pruebas aprobadas. ¡Gracias!
