I wanted to know if there was a way to enable a sort feature for forums that have the solved plugin enabled to sort by Unsolved/Solved questions? The same way that we can sort on a Category by “Latest”, “New”, “Top”, “Unread” by clicking the link at the top.
I understand that this was sort of asked before, but I’m not sure exactly how to add a new sort “option” that has a link to reorganize the topics by those query params.
In this way you add the buttons Solved and Unsolved on your menu.
You need only to change the URLs with your domain (and customize with a particular category if you want, eg http://your-domain-url/c/support?solved=yes)
I had the same question but didn’t quite understand how to make it happen. Where do I add this script?
Would it possible to have a configuration button or setting checkbox to enable sorting by solved?
It would really nice to have a button to sort or show only solved/unsolved posts. I know @david suggested a workaround to add custom HTML but if the plugin did that it would be awesome.
I had a very brief look at adding it in the form of a theme component, but I think it will need some changes in the plugin itself first.
I think we need to a Boolean to the category serialiser, as currently there’s no way to know whether a category has “discourse-solved” enabled, its only shipped to the client on a “per-topic” basis.
@vinothkannans this is just so close to your other theme component, maybe also do one for this … “adds a [all/solved/unsolved] combo to categories with solved enabled?”
In fact, I would just add this to the plugin and have it be a default off site setting.
