Admin links naar vertrouwensniveaus kapot als vertrouwensniveaus worden hernoemd
The issue of broken admin links to trust levels after renaming has been reported. Originally, pfaffman noticed that clicking on a trust level number redirects to a non-functional route. jomaxro linked a possibly related bug, but Ed_S notes that their issue occurred without renaming. pfaffman confirms the similarity. A fix is proposed in a pull request jamie.wilson shared on GitHub.
if you click on the “4” you’re directed to admin/users/list/Level%202 but that route doesn’t work.
I’ll link to the customer site in a flag.
Is this the same bug as Dashboard has wrong links for member trust levels ?
(Looks like similar symptoms, to me, but note that in my case I didn’t do any renaming.)
Oh! Apparently so. It’s worse than I thought! :wink:
https://github.com/discourse/discourse/pull/13588
The above PR should fix the problem.
