管理员修改用户姓名(非用户名)应被记录
Not sure if this is a bug or a feature, but it looks like when you edit a user’s name, it’s not logged at all as far as I can tell. So for example, if I, as an admin, go to a different user’s preference page, and set the “Name” field. The same goes for if you set it through the admin panel.
That should probably be logged, shouldn’t it?
1 个赞
Seems like a reasonable request and a good starter task cc @erlend_sh
4 个赞
Hi @codinghorror ,
I looked for this bug and I was able to reproduce it.
On investigation, I found out that change of name was getting logged in UserHistory table but it is not shown in UI because it is not a part of staff_actions. I will try to submit PR for this change.
Let me know if you have any suggestions.
Thanks
10 个赞
Awesome :confetti_ball:
2 个赞
Merged! Thank you @saurabhp
8 个赞
