I’m currently trying to setup Google Adsense for Discourse, I use the Standard payment option with a custom domain. I have entered the domain into Adsense and have now moved onto the’Verify Site Ownership’ tab. I have pasted the Ads.txt snippet into:
And in the Dev Tools it returns Status Code: 200 OK under network.
However my issue is when attempting to press the verify button on the Adsense page it says ’ Couldn’t verify your site
We couldn’t verify your site. Make sure that the changes you made to your site are published and accessible by the Google AdSense crawler. If you’re still having issues try another method.’
I’m unsure of how to proceed with this, and most of the documentation forms i’ve seen are for people hosting discourse themselves and not using the Standard payment plan with Discourse.
If anyone has any knowledge on this please let me know.
Thank you.
Just to check, did you also add these bits to the settings as well:
As a hosted customer you can also contact the dedicated customer support channel at team@discourse.org if you get stuck with anything. They have the ability to check your setup in much more detail than community support (though all are welcome here )
I mainly found the documentation abit confusing since I had to decipher between what was on the self hosting side of it and the Discourse hosting lol. I believe I put in the Publisher ID however Adsense didn’t provide the rest
I thought I’d give it a run-through myself as it’s been a while since I last played with it. However I’m also hitting a snag… It wants me to verify the main domain and not the subdomain my site is on. I am not sure how to do this as I don’t have anything on the main domain.
