Lengte van account op hold aanpassen wegens te snel typen
Users are discussing the system’s automatic suspension of new accounts that type too fast, intended to prevent bots. Crius notes the current suspension duration seems too short for staff review and asks if it can be adjusted. JammyDodger clarifies that suspensions are meant to last until staff manually review the account — citing an example where a user was silenced until December 23, 3023 — though Crius suspects some may have been unblocked unnoticed. dennisjbr confirms they’re also experiencing the issue, noting the system is overly sensitive. JammyDodger adds that the setting was recently updated and is now called Fast typing threshold, replacing the old min first post typing time. It allows admins to set a minimum typing duration (1s, 3s, or 5s) before the first post is auto-sent to review — not necessarily suspended — depending on the chosen threshold. The confusion may stem from misunderstanding whether the account is truly suspended or just queued for review.
Currently seems like the system temporarily hold accounts that “type too fast” after creating a new account as a measure to prevent bots.
Which is fine. However, I don’t understand if there is somewhere an option to change this length. I would prefer is those users are suspended for a longer time so that I can be sure that someone from staff review it. Currently, the time windows seem very short (but it might depend on from the availability of your staff I suppose)
I thought they were silenced for 1000 years (effectively, ‘until a staff member deals with it’).
I’ve dug out an example from here on meta - ‘@system silenced this account until December 23, 3023. Reason: New user typed too fast’
Weird, maybe some moderator unblocked the users without me noticing. I’ll double check next time it happens. Cheers
Did you find this setting? We are getting this error too when a user supposedly typed too fast. It’s very sensitive.
I believe this setting has had a recent update and is now called Fast typing threshold [1]:
Minimum amount of time in milliseconds a user must type for their first post. If the threshold is not met, the post will automatically enter the review queue. Low is 1 second, standard is 3 seconds, high is 5 seconds.
  1. updated from min first post typing time ↩︎
