Anyone having issues sending to comcast.net addresses using mailgun? <SOLVED>
I switched to mailgun after mandrell went away as suggested in discourse. However, now all of my emails sent to comcast.net email addresses are failing with: “550 5.1.0 Invalid sender domain”. It works for every non comcast customer though.
This obviously isn’t an issue with discourse, but I was hoping someone might have some insight. I called comcast and they were completely useless and have opened a ticket with Rackspace. We will see what they say. In the meantime…
Thanks for any help!
I figured it out. I thought I would document it here in case anyone else needs help in the future.
The sender of the email was coming across at comcast as ‘xx@mg.mydomain.com’, which comcast was trying to verify.
I needed an additional MX record. I use Google Apps for normal emails, but also Mailgun. I had all the Google Apps MX records, but what I had to do was add an additional MX record with a subdomain of “mg” for mailgun, which I just pointed at google server. Here are my MX records, which seem to now be working:
MX Records
Mail Server	Preference	Subdomain	TTL
aspmx.l.google.com	1		Default
alt1.aspmx.l.google.com	5		Default
alt2.aspmx.l.google.com	5		Default
alt3.aspmx.l.google.com	10		Default
alt4.aspmx.l.google.com	10		Default
aspmx.l.google.com	20	mg	Default
Hey, danke, Kumpel! Ich habe heute das gleiche Problem mit einem Comcast-Nutzer und Mailgun gehabt. Jetzt muss ich herausfinden, wie ich am besten mit MX-Einträgen umgehe.
Ich wollte auch meinen Dank dafür aussprechen, dass du die Antwort hier geteilt hast! Das war eine einfache Lösung.
