Heeft iemand SMTP ingesteld met mailjet?
In a discussion titled “Anyone setup SMTP with mailjet?” under the Installation category, maze1g seeks help configuring Mailjet SMTP for their Discourse installation. After following a guide linked by pfaffman, they encounter an error during TXT record verification maze1g. pfaffman advises checking DNS setup specific to their provider, while rorycb confirms success using the same guide and suggests contacting Mailjet support. maze1g details their setup: WordPress on Dreamhost, Cloudflare as CDN, Discourse on DigitalOcean, and Mailjet configured via mailjet.mywebsite.com. The error — “Neither the file at your domain root nor the DNS TXT record have been found” — stems from misconfigured DNS. rorycb clarifies that DNS records must be set where the domain is managed (likely Dreamhost), and pfaffman recommends using forum.mywebsite.com as the mail domain and suggests verifying record existence. Ultimately, maze1g resolves the issue by appending .forum to the TXT record’s “Name” field (e.g., mailjet._abcdef.forum), aligning it with their subdomain. The thread concludes with gratitude and a smiley emoji.
Having trouble with my first time installation of discourse, would be grateful if someone can help!
TIA
If you Search results for 'mailjet' - Discourse Meta
You can find Howto use Mailjet as a free SMTP service for Discourse
Thanks Jay. So I initially was following the guide you sent, but I got an error when it came to setting up the TXT.
Then that’s what you need to get help on. And it has nothing to do with Discourse.
You should google “create TXT record [DNS service]”.
Both of mine are running on MailJet, using the guide Jay linked to - It would probably be helpful to know the error you’re running into - it may be better to get support from MailJet depending what your error is.
So just to give you an idea of what I’ve done thus far:
  1. Made mywebsite.com using dreamhost (wordpress)
  2. Using Cloudflare as CDN
  3. Digitalocean droplet for discourse
  4. Added forum.mywebsite.com on cloudflare, which worked on the console during discourse installation
  5. Signed up mailjet for the SMTP, using mailjet.mywebsite.com on cloudflare
  6. Having trouble getting mailjet to verify DNS TXT record on cloudflare
So when I try to create a DNS record on cloudflare via TXT, I get the error:
“Neither the file at your domain root nor the DNS TXT record have been found to validate this domain. Please check your configuration and try again.”
Not sure where I’m messing up. Is there anything I’m supposed to be doing on dreamhost?
TIA
Who is your DNS service Cloudflare, or Dreamhost? that is where the TXT entry needs to be. Given your error I’d assume it is dreamhost.
You should use forum.mywebsite.com for the mail domain.
If you’re getting that error then your didn’t create the a record it’s asking for. If your share the name we could do a lookup to see if the record existed.
Asking mail jet for help might be a good idea.
Got it figured out!
The DNS entry they told me for the “Name” was “mailjet._abcdef”, what I needed to do was add .forum to the end of it because that’s the subdomain I wanted. So ““mailjet._abcdef.forum”.
Thanks for your help :slight_smile:
