When a default user option is set from false to true, it doesn’t behave like it should.
It does not ask if the setting should be applied to existing users and even if it did, that wouldn’t work.
Repro:
- Have a setting like for instance “open external links in new tab” enabled
- Set admin - settings - user preferences -
default other external links in new tab
to enabled - Set admin - settings - user preferences -
to disabled - Get a popup
Would you like to apply this change historically? This will change preferences for X existing users.
and choose Yes - For all users the “open external links in new tab” is now disabled
So far so good, but:
to enabled - Get no popup and it is still disabled for everyone.
Expected last step:
- Get a popup
where choosing Yes would enable it for everyone
This goes for all default_
user preferences.
This seems to be related to here and here
previous_value = SiteSetting.public_send(id) || "" if update_existing_users
which sets previous_value to ""
if the setting is false
, and then
UserOption.where(user_option => previous_value).update_all(attrs)
and
json[:user_count] = UserOption.where(user_option => previous_value).
doesn’t do anything.
