Ziitoo
(Ziitoo)
April 21, 2024, 9:30am
1
Please help me with a cheaper linux vps with docker support .
I am not sure if my forum will get visitors or not , I am just starting to see if I can scale . so going for a $30 per month server is not possible for me , so I am thinking to start from the very basic .
please please suggest me good vps for starting .
thoka
(Thomas Kalka)
April 21, 2024, 10:02am
I would consider individual suggestions for cheap and reliable hosting outside the scope of this website.
You will find some information about minimal requirements to run docker in this thread:
The minimum hardware requirements for install notes
1 GB RAM minimum (with swap )
The link for swap notes
For servers with <= 2GB of RAM, running ./discourse-setup will prompt for and automatically create a 2GB swapfile.
So here is my take, if it is wrong I am sure others are thinking wrong.
Note: I have never installed Discourse into production (did a dev install).
If one ask a provider for a server with 1 GB of ram I take it during the install it would grab an additional 2 GB fo…
