After upgrading to the latest version 8fa9ed8572, I get a blank screen in the admin upgrade page
And the following error in the logs (/admin/docker/repos)
lib/version.rb:35:in `find_compatible_resource'
lib/version.rb:56:in `find_compatible_git_resource'
plugins/docker_manager/lib/docker_manager/git_repo.rb:118:in `tracking_branch'
plugins/docker_manager/lib/docker_manager/git_repo.rb:11:in `initialize'
plugins/docker_manager/lib/docker_manager/git_repo.rb:79:in `new'
plugins/docker_manager/lib/docker_manager/git_repo.rb:79:in `block in find_all'
plugins/docker_manager/lib/docker_manager/git_repo.rb:82:in `each'
plugins/docker_manager/lib/docker_manager/git_repo.rb:82:in `find_all'
plugins/docker_manager/app/controllers/docker_manager/admin_controller.rb:28:in `repos'
actionpack (6.0.3.3) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (6.0.3.3) lib/abstract_controller/base.rb:195:in `process_action'
actionpack (6.0.3.3) lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack (6.0.3.3) lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport (6.0.3.3) lib/active_support/callbacks.rb:135:in `run_callbacks'
actionpack (6.0.3.3) lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack (6.0.3.3) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (6.0.3.3) lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
activesupport (6.0.3.3) lib/active_support/notifications.rb:180:in `block in instrument'
activesupport (6.0.3.3) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (6.0.3.3) lib/active_support/notifications.rb:180:in `instrument'
actionpack (6.0.3.3) lib/action_controller/metal/instrumentation.rb:32:in `process_action'
actionpack (6.0.3.3) lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
activerecord (6.0.3.3) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (6.0.3.3) lib/abstract_controller/base.rb:136:in `process'
actionview (6.0.3.3) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (2.1.0) lib/mini_profiler/profiling_methods.rb:104:in `block in profile_method'
actionpack (6.0.3.3) lib/action_controller/metal.rb:190:in `dispatch'
actionpack (6.0.3.3) lib/action_controller/metal.rb:254:in `dispatch'
actionpack (6.0.3.3) lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
actionpack (6.0.3.3) lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack (6.0.3.3) lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
actionpack (6.0.3.3) lib/action_dispatch/routing/mapper.rb:48:in `serve'
actionpack (6.0.3.3) lib/action_dispatch/journey/router.rb:49:in `block in serve'
actionpack (6.0.3.3) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (6.0.3.3) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (6.0.3.3) lib/action_dispatch/routing/route_set.rb:834:in `call'
railties (6.0.3.3) lib/rails/engine.rb:527:in `call'
railties (6.0.3.3) lib/rails/railtie.rb:190:in `public_send'
railties (6.0.3.3) lib/rails/railtie.rb:190:in `method_missing'
actionpack (6.0.3.3) lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>'
lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
rack (2.2.3) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.3) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.3) lib/rack/head.rb:12:in `call'
lib/middleware/anonymous_cache.rb:336:in `call'
rack (2.2.3) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.3) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/cookies.rb:648:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (6.0.3.3) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (6.0.3.3) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster (2.9.4) lib/logster/middleware/reporter.rb:43:in `call'
railties (6.0.3.3) lib/rails/rack/logger.rb:37:in `call_app'
railties (6.0.3.3) lib/rails/rack/logger.rb:28:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/request_id.rb:27:in `call'
lib/middleware/enforce_hostname.rb:22:in `call'
rack (2.2.3) lib/rack/method_override.rb:24:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.3) lib/rack/sendfile.rb:110:in `call'
actionpack (6.0.3.3) lib/action_dispatch/middleware/host_authorization.rb:76:in `call'
rack-mini-profiler (2.1.0) lib/mini_profiler/profiler.rb:357:in `call'
message_bus (3.3.4) lib/message_bus/rack/middleware.rb:61:in `call'
lib/middleware/request_tracker.rb:176:in `call'
rack (2.2.3) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.3) lib/rack/urlmap.rb:58:in `each'
rack (2.2.3) lib/rack/urlmap.rb:58:in `call'
unicorn (5.7.0) lib/unicorn/http_server.rb:632:in `process_client'
unicorn (5.7.0) lib/unicorn/http_server.rb:728:in `worker_loop'
unicorn (5.7.0) lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
unicorn (5.7.0) lib/unicorn/http_server.rb:144:in `start'
unicorn (5.7.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
I haven’t added any new plugins (all I have are the Discourse official plugins) and upgrading by rebuilding the image still works.
Fixed in:
