In a support thread titled ‘Bogus Dashboard advice’, Paul_King reports that after updating to Discourse 3.6.0.beta3-latest, the dashboard displays a misleading warning that force_https is not enabled — yet clicking the linked setting yields no results. RGJ references prior threads indicating the setting is now hidden, especially for Let’s Encrypt users. Paul_King suggests the dashboard message should be updated to reflect this. pfaffman asks if it’s a standard install, noting newer versions use a different numbering system; Paul_King confirms a Digital Ocean Ubuntu 24.04.3 setup via git pull. After updating to 2025.12.0-latest, the warning persists Paul_King. italo explains the setting is not accessible via the admin dashboard and must be set via Rails console or by editing app.yml, which Paul_King confirms resolves both the dashboard warning and mixed-content image issues on the login page. The consensus is that the dashboard’s warning is outdated or misleading, and the setting should ideally be auto-enabled post-installation for Let’s Encrypt setups.
As far as I know it was a standard install in the sense of being on a Digital Ocean droplet running Ubuntu 24.04.3, installed using git pull, although beyond that I would likely not notice if things had gone off-piste somehow.
Below is what I see on Dashboard - is the code in blue from the new numbering system?
Looks like I a bug, as I’m seeing this on a CDCK hosted site that’s running 63d923e144bbc46cf78efd686164938c5699209d (it just restored a backup, if that makes a difference).
But it went away when the backup finished restoring.
Thanks @italo This solved another issue as well, with mixed http and https references to image assets on my login dialog.
In my case, app.yml had this set to false - editing app.yml and rebuilding, and the error is now gone from dashboard, and the site logo now appears on the login dialog.
