Bootstrap Failed, out of memory error
I tried searching through the forum for troubleshooting but couldn’t find a similar error code that other people have encountered. Would someone shed light on what I have done wrong?
FAILED
RuntimeError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile' failed with return # <Process::Status: pid 318 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}    6a33a6d3658bf0bcba03364c855763ff6213a357b8190077daa6ddf9a9335bc1
FAILED TO BOOTSTRAP
I followed the standard installation procedure.
Many thanks in advance!
If you have the adsense plugin installed, please read this
https://meta.discourse.org/t/upgrade-failed-due-to-adsense-plugin/28671
Thanks @Mittineague. Where can I find the AdSense file? Sorry I am new to coding.
In the “plugins” folder
Can you clarify, are you installing for the first time? Did you follow our official install guide?
But I have never downloaded the file? Am I supposed to do it in Terminal?
Yes I am installing it the first time. Yes I followed your official install guide.
The most common error is bad formatting in the app.yml file. I suggest going back and making sure every single character is correct, including the correct number of spaces in front of each line.
I replaced “example” with my own email and site credential and deleted the “#” in front of the line, where “#” exist for the line I made changes in. Are there other spacing rules that I might not be aware of?
 LANG: en_US.UTF-8
 ## TODO: How many concurrent web requests are supported?
 ## With 2GB we recommend 3-4 workers, with 1GB only 2
 #UNICORN_WORKERS: 2
 DISCOURSE_DEVELOPER_EMAILS: 'xxx@xxxxx.com'
 DISCOURSE_HOSTNAME: 'xxx.xxxxxxx.com'
 ## TODO: The mailserver this Discourse instance will use
 DISCOURSE_SMTP_ADDRESS: smtp.mandrillapp.com         # (mandatory)
 DISCOURSE_SMTP_PORT: 587                        # (optional)
 DISCOURSE_SMTP_USER_NAME: xxxxxxx@xxxx.com      # (optional)
 DISCOURSE_SMTP_PASSWORD: xxxxxxxx               # (optional)
 #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
 ## The CDN address for this Discourse instance (configured to pull)
 #DISCOURSE_CDN_URL: //discourse-cdn.example.com
Here are my configurations (I x-ed out my credentials). I gather that everything is aligned?
I suggest pasting the entire app.yml file in an online YAML validator like
If you are doing a simple install that’s the first thing to verify.
YAMLlint says it is a valid YAML. What else could be the problem? :confused:
Not sure we would need the complete install log, the error is usually upstream. Did you add any extra steps or deviate from our install guide in any way?
No. The only thing I skipped was setting up Swap.
Swap is needed for 1 GB RAM, but can be optional for 2 GB. Maybe attach a text file of the complete install log here.
I install from the guide multiple times per week and I have no issues. But I install religiously following the guide to the letter every step of the way.
I tried the installation for the 3rd time but it is still not working. Here is the install log. Thanks a lot!
Discourse Installation 3.txt (216.8 KB)
I followed the guide that @Qasem_h posted and it now works! Not sure if the extra step I took to update and upgrade the system had made a difference. Thanks a lot everyone!
https://www.digitalocean.com/community/tutorials/how-to-install-discourse-on-ubuntu-14-04
Looking at your logs, you hit an out of memory error. So not following the guide and setting up a swap file is what caused the problem.
