Hi there,
I am running Discourse version v1.8.0.beta8 +16 with Solved plugin 0.1, but the CSS seems to be broken. The icon is not green a the text is not aligned.
Any tips?
Hi there,
Any tips?
Do you have any CSS customisations on your site?
If it’s a public forum, can you share a link so we can have a look?
No CSS customizations I know of. I’ve made it public just for you https://platforma.slovensko.digital/c/stat-overflow ![]()
Thanks for the quick reply!
That is weird… it seems like the CSS from the plugin hasn’t been included at all…
How did you install the plugin? Are you using the standard docker-based install?
I just added the plugin in the app.yml
after_code:
- exec:
cd: $home/plugins
cmd:
- mkdir -p plugins
- git clone https://github.com/discourse/discourse-solved.git
and rebuild the app. Worked ok until I upgraded the discourse via admin GUI. Yup. Running the standard docker installation.
That all looks fine, can you try rebuilding the site from the command line again:
/var/discourse/launcher rebuild app and see if the problem persists? It might be that the GUI upgrade got stuck when compiling the CSS.
Hmm, this fixed it. Will let you know if anything goes wrong after another upgrade from GUI.
Thanks!
