באג ביומן בנייד
Hello, I have a problem on discourse on mobile with the event calendar plugin. When I create an event and want to notify a user, it doesn’t work, but there are no issues on the computer. Do you have the same problem? Thank you.
I also take this opportunity to see if there is a possibility to view the entire calendar inserted into a category on mobile because it is perfect on the computer. :sweat_smile:
i’m not sure what you mean, i find the calendar full-width / large on a computer
perhaps the category isn’t on the plugin setting below
because the category is in that setting, on mobile i see
I would like to see the monthly view in the category on a mobile device. Currently, I have the weekly view by default on mobile. I wanted to know if there is a solution to work around this issue.
לייק 1
see also user preference, an extension to /upcoming-events / /c/ granularity (as you’ve suggested)
I’ve opened a small PR related to this:
https://github.com/discourse/discourse/pull/39963
It adds a calendar_category_default_view site setting, so category calendars can have a configurable default view rather than relying only on the current fallback behaviour.
It still needs review/approval, so it is not available yet, but it may be relevant to the monthly-view-on-mobile use case here.
2 לייקים
Great @Ethsim2, I think your addition will be useful to others in the Discourse community :+1:
At least you have me :sweat_smile:
There is a workaround using the advanced calendar_categories setting, for example:
categoryId=123;defaultView=month
But I agree this is not ideal if you want the same default view for many category calendars, because it means manually listing category IDs.
That is why I opened this PR
The idea is to add a global calendar_category_default_view setting, while still allowing per-category defaultView to override it where needed.
לייק 1
https://github.com/discourse/discourse/pull/40060
