Échec du processus d'invitation en masse : No such file or directory @ rb_sysopen
Hi there,
I’ve been trying to upload an csv file for a bulk invite, but each time I receive this message:
Bulk Invite Process Failed – 'No such file or directory @ rb_sysopen
Can someone please help? I am not familiar with Discourse. This is urgent as I am supposed to be launching the entire site by Friday… but that won’t be possible if I can’t invite our users.
Thank you! :slight_smile:
Hi, @lana. Welcome aboard.
I just tested an invite on one my my systems and it worked fine; I don’t remember seeing any reports with invites in recent memory. Did you do a standard install? Did the file you uploaded have a funny name somehow? Did you upload a plain-text csv file? (None if these seems like especially likely explanations).
There is free help here, but if you end up with more money than time I provide paid support.
Hi there,
Is there anyone here from Discourse that could help? I do not have any errors on my list, and Im using an csv file…
Please help :frowning: @techAPJ
Are you on latest Discourse version? Also are you seeing any relevant errors in forum.example.com/logs?
I tested locally and bulk invite process works fine for me, so this seems specific to your setup. Maybe try rebuilding the instance and then try again?
cd /var/discourse/
./launcher rebuild app
How did you install discourse?
Hi @techAPJ
thanks for your response!
I’m not sure how we installed Discourse but rebuilding would mean loosing all my configuration right?
I have someone in our tech team trying to help out. Could it be because of a bad internet connexion for instance?
Not at all. It means running the rebuild command to update your instance to the latest version.
cd /var/discourse
Right. Thanks @zogstrip …
I think my tech team has found the issue. But it seems too technical for me to understand. Only thing is, when we finally managed to send invites, only 209 out of 340 were showing as Pending.
So was there something wrong with the CSV? This feature has worked well for years now.
Je peux confirmer que ce problème est toujours présent. Le fait est qu’il finit par fonctionner.
Parfois, je dois télécharger le même fichier encore et encore jusqu’à ce qu’il soit traité correctement.
Mais cela a toujours fini par fonctionner.
I’ve been doing it at least 6 times now, still no success. You’re lucky @loginerror !
Continuez d’essayer ! Pour un meilleur effet, attendez quelques secondes après chaque clic. C’est probablement un effet placebo, mais ça finit par marcher :smiley:
We recently pushed a proper fix here:
https://github.com/discourse/discourse/commit/e7fe7010b8dcea495a46089c9fd5ec215f3de46e
This should be no longer an issue.
