Posso aceitar mais de uma resposta?
Will it allow you to select more than one? I can see it being useful if two people each contribute half of the solution.
3 curtidas
There are no plans to allow users to select more than one answer, it would heavily complicate the plugin.
I would recommend creating a more complete answer if desired and maybe even wiki’ing it.
Fechado em favor de Can multiple replies be marked as the solution?
