לא ניתן עוד להקצות סגנון אווטאר על ידי הגדרת קבוצה ראשית
סיכום מבוסס בינה מלאכותית
A bug has been reported where setting a primary group no longer automatically assigns the group’s avatar flair to users. Grayden_Shand used to be able to set the flair in the group settings, but this functionality appears to have been broken by the addition of a user preference setting for selecting avatar flair.
nathank has provided a temporary workaround using a rails console code snippet, which forces group members to have the group avatar. An improved version of the code snippet has also been shared. However, nathank has reported that changes to the primary group setting still do not update the user’s flair to the group flair, suggesting the issue persists.
vinothkannans claims to have added a fix for this issue in a GitHub pull request (PR #1476), but its effectiveness is uncertain.
I would like to give all users in a group an avatar flair.
I used to be able to set the flair in the group settings, check the “Automatically set as primary group” option, and everyone in the group would automatically get the flair added to their avatar.
Now, however, it seems that a user’s flair is not associated with their primary group. I can verify that a user’s primary group is correctly set, but their avatar still does not display the flair.
While poking around, I noticed a new setting on the user preferences page that allows users to select their own flair.
I’m guessing that the addition of this preference setting broke the association between a user’s primary group and their avatar flair.
Question: Is there any way now to bulk assign the flair for every user in a group? I don’t want to message the group and instruct them all on how to set this in their preferences, and I don’t want to go through one by one and update each user’s preferences for them.
This forces group members to have the group avatar:
rails c
 target_group = Group.find_by_name("=GroupSlug=")
 users = User.joins(:group_users).where(group_users:{group_id: target_group.id})
 users.each do |u|
  u.flair_group_id = target_group.id
  u.save
Exit
https://github.com/discourse/discourse/pull/14762
I added a fix for this issue in the above PR.
I’ve just been trying this again.
I noticed that changes to the primary group setting didn’t seem to update the user’s flair to the group flair. Is the fix above still working?
On a bright note, I improved my little rails console code snippet above so you only need the group slug (and confirmed that it still works!).
