Cannot skip forward in edit history
Since my topic Updating on the beta-channel still gives ±versions was recategorized, the edit history is broken. If you open the edit history on that post and click Previous revision to see the first edit, no Next revision button shows up.
5 إعجابات
Something for you to look at @zogstrip.
Thanks for reporting that issue @fefrei. I just pushed a fix :rat:
3 إعجابات
