Cannot switch a topic to Uncategorized via quick edit
It’s impossible to change the category of a topic to “Uncategorized” through the edit topic title feature. Changing to other categories seems to work fine.
Using the bulk selection tool to change the category to “Uncategorized” is working, so it seems isolated to the edit topic title feature.
12 לייקים
Does it work if you press the edit button on the first post? Or is the quick edit the only place this happens?
3 לייקים
Quick edit seems to be the only place having issues. Editing the first post and changing the category to “Uncategorized” through the composer works no problem.
3 לייקים
@j.jaffeux can you have a look?
4 לייקים
That should fix it:
Thanks
9 לייקים
This topic was automatically closed after 4 hours. New replies are no longer allowed.
