Un abonné a voulu annuler son abonnement et a demandé l’aide d’un autre administrateur. Lorsque l’administrateur a essayé d’annuler, il a signalé que rien ne se passait et que l’abonnement était toujours actif. J’ai consulté les journaux et découvert cette erreur :
NoMethodError (undefined method `delete' for class Stripe::Subscription)
Voici la trace de la pile :
plugins/discourse-subscriptions/app/controllers/discourse_subscriptions/admin/subscriptions_controller.rb:56:in `destroy'
actionpack (7.0.8.4) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.8.4) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.0.8.4) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
i18n (1.14.5) lib/i18n.rb:351:in `with_locale'
app/controllers/application_controller.rb:424:in `with_resolved_locale'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.8.4) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.8.4) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.8.4) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.8.4) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.8.4) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.8.4) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.8.4) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.8.4) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack (7.0.8.4) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.8.4) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.8.4) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.8.4) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.8.4) lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
actionpack (7.0.8.4) lib/action_dispatch/routing/mapper.rb:48:in `serve'
actionpack (7.0.8.4) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.8.4) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.8.4) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.8.4) lib/action_dispatch/routing/route_set.rb:852:in `call'
railties (7.0.8.4) lib/rails/engine.rb:530:in `call'
railties (7.0.8.4) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.8.4) lib/rails/railtie.rb:226:in `method_missing'
actionpack (7.0.8.4) lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack (2.2.9) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.9) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.9) lib/rack/head.rb:12:in `call'
actionpack (7.0.8.4) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
lib/middleware/anonymous_cache.rb:393:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
rack (2.2.9) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.9) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.8.4) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster (2.19.1) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.0.8.4) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.8.4) lib/rails/rack/logger.rb:27:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/request_id.rb:26:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
rack (2.2.9) lib/rack/method_override.rb:24:in `call'
rack (2.2.9) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:191:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
lib/middleware/request_tracker.rb:360:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
rails_multisite (6.0.0) lib/rails_multisite/middleware.rb:26:in `call'
rack (2.2.9) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.9) lib/rack/urlmap.rb:58:in `each'
rack (2.2.9) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
J’utilise cette version du plugin d’abonnement.
J’ai vérifié la configuration sur Stripe et elle écoute deux webhooks :
customer.subscription.deleted
customer.subscription.updated
D’après les journaux Stripe, je vois que customer.subscription.updated a réussi récemment et que customer.subscription.deleted n’a pas été appelé. (Ce n’est pas surprenant, car c’est la première fois qu’un client annule, d’après ce que nous pouvons constater.)
Ma prochaine étape est de mettre à jour Discourse et le plugin d’abonnement. Je pense que nous pouvons également utiliser le site Web Stripe pour annuler cet abonnement, mais je préférerais vérifier que cela fonctionne comme prévu.
Y a-t-il autre chose que je devrais examiner ?
