لا يمكن تعديل إعدادات WP-Discourse
Hello,
I need to create a WP/Discourse forum, so i install WP-Discourse on my WP with an OS in PHP 5.4.16. Because i want Caldera Form plugin to post automatically form content, I install the required version of PHP for Caldera, PHP 5.6.
And it’s a this moment that i notice i can’t change the Discourse configuration. When I change a parameter and i save, the change are automatically reset. I try to reinstall the plugin, but nothing change.
Anyone know the problems ?
إعجاب واحد (1)
Maybe start by looking at your server’s php error logs?
looks like some extension (probably cURL) is not installed.
Problem solve.
To upgrade the OS to PHP5.6, we use a script, and the script create a problem between cURL and Discourse. So we downgrade the version and find an alternative to Caldera Form.
Thank for the help
5 إعجابات
