I just setup my site discuss.wmpoweruser.com - but, the WP Discourse plugin isn’t working for some reason. It isn’t posting the new posts automatically to the Discourse site for some reason.
How do I fix this?
How do I fix this?
What version if Discourse / WordPress / WP-Discourse plugin are you on?
I am using the latest version of all of these. So:
Discourse: 1.5.0.beta5
WordPress: 4.3.1
WP-Discourse: 0.6.6
Couldn’t get this sorted yet. Anyone have any ideas?
If the plugin isn’t working then you’re running into an issue with the settings/configuration
Ok, got it sorted. Thanks guys!
Could you please explain what part of the configuration was tripped up, and how you solved it? Will be helpful in case anyone else runs into the same problem
So I revoked the first API key, regenerated a new one and that solved the issue. Quite weird.
