No se puede reconstruir, falta clang-11
We can’t rebuild our forum right now, clang-11 is missing when we try to rebuild, even though I explicitly installed it before the second rebuild, and it looks like it’s getting installed anyways no wait, that’s clang-13.
Log:
/var/discourse$ sudo ./launcher rebuild app
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20231218-0429: Pulling from discourse/base
Digest: sha256:468f70b9bb4c6d0c6c2bbb3efc1a5e12d145eae57bdb6946b7fe5558beb52dc1
Status: Image is up to date for discourse/base:2.0.20231218-0429
docker.io/discourse/base:2.0.20231218-0429
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-02-10T15:28:35.122634 #1]  INFO -- : Reading from stdin
I, [2024-02-10T15:28:35.142265 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2024-02-10T15:28:35.181057 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-02-10T15:28:35.181628 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2024-02-10T15:28:35.185106 #1]  INFO -- :
I, [2024-02-10T15:28:35.185365 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2024-02-10T15:28:35.188651 #1]  INFO -- :
I, [2024-02-10T15:28:35.188944 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2024-02-10T15:28:35.191894 #1]  INFO -- :
I, [2024-02-10T15:28:35.192222 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2024-02-10T15:28:35.195618 #1]  INFO -- :
I, [2024-02-10T15:28:35.195905 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2024-02-10T15:28:35.198851 #1]  INFO -- :
I, [2024-02-10T15:28:35.199100 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2024/02/10 15:28:35 socat[19] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2024-02-10T15:28:35.205774 #1]  INFO -- :
I, [2024-02-10T15:28:35.206094 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2024-02-10T15:28:35.209888 #1]  INFO -- :
I, [2024-02-10T15:28:35.210069 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2024-02-10T15:28:35.213707 #1]  INFO -- :
I, [2024-02-10T15:28:35.213878 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2024-02-10T15:28:35.217149 #1]  INFO -- :
I, [2024-02-10T15:28:35.217401 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2024-02-10T15:28:35.220318 #1]  INFO -- :
I, [2024-02-10T15:28:35.227008 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-02-10T15:28:35.234016 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-02-10T15:28:35.240402 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-02-10T15:28:35.247649 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-02-10T15:28:35.248441 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2024-02-10T15:28:37.002477 #1]  INFO -- :
I, [2024-02-10T15:28:37.004175 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2024-02-10T15:28:37.008266 #1]  INFO -- :
I, [2024-02-10T15:28:37.008335 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2024-02-10T15:28:37.038629 #1]  INFO -- :
I, [2024-02-10T15:28:37.038939 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2024-02-10T15:28:37.042496 #1]  INFO -- :
I, [2024-02-10T15:28:37.042849 #1]  INFO -- : > /root/upgrade_postgres
I, [2024-02-10T15:28:37.048708 #1]  INFO -- :
I, [2024-02-10T15:28:37.048890 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2024-02-10T15:28:37.052134 #1]  INFO -- :
I, [2024-02-10T15:28:37.052483 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-10T15:28:37.053142 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-10T15:28:37.053492 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-10T15:28:37.053771 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-10T15:28:37.054097 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-10T15:28:37.054357 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-10T15:28:37.054596 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2024-02-10T15:28:37.058458 #1]  INFO -- :
I, [2024-02-10T15:28:37.058916 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-10T15:28:37.059288 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-10T15:28:37.059557 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-02-10T15:28:37.059821 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-10T15:28:37.063135 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-10T15:28:37.063715 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-02-10T15:28:37.065548 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-02-10T15:28:37.068396 #1]  INFO -- : > sleep 5
2024-02-10 15:28:37.151 UTC [42] LOG:  starting PostgreSQL 13.13 (Debian 13.13-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-02-10 15:28:37.151 UTC [42] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-02-10 15:28:37.151 UTC [42] LOG:  listening on IPv6 address "::", port 5432
2024-02-10 15:28:37.156 UTC [42] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-02-10 15:28:37.166 UTC [45] LOG:  database system was shut down at 2024-02-10 15:25:08 UTC
2024-02-10 15:28:37.177 UTC [42] LOG:  database system is ready to accept connections
I, [2024-02-10T15:28:42.071570 #1]  INFO -- :
I, [2024-02-10T15:28:42.071977 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2024-02-10 15:28:42.126 UTC [55] postgres@postgres ERROR:  database "discourse" already exists
2024-02-10 15:28:42.126 UTC [55] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2024-02-10T15:28:42.128636 #1]  INFO -- :
I, [2024-02-10T15:28:42.129090 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2024-02-10 15:28:42.183 UTC [59] postgres@discourse ERROR:  role "discourse" already exists
2024-02-10 15:28:42.183 UTC [59] postgres@discourse STATEMENT:  create user discourse;
I, [2024-02-10T15:28:42.185457 #1]  INFO -- :
I, [2024-02-10T15:28:42.185710 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2024-02-10T15:28:42.239654 #1]  INFO -- : GRANT
I, [2024-02-10T15:28:42.239902 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2024-02-10T15:28:42.294966 #1]  INFO -- : ALTER SCHEMA
I, [2024-02-10T15:28:42.295380 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2024-02-10T15:28:42.352139 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-10T15:28:42.352454 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2024-02-10T15:28:42.405562 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-10T15:28:42.405820 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists vector;"'
NOTICE:  extension "vector" already exists, skipping
I, [2024-02-10T15:28:42.458746 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-10T15:28:42.458964 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2024-02-10T15:28:42.513251 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-10T15:28:42.513487 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2024-02-10T15:28:42.567363 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-10T15:28:42.568213 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists vector;"'
I, [2024-02-10T15:28:42.622689 #1]  INFO -- : CREATE EXTENSION
I, [2024-02-10T15:28:42.623681 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2024-02-10T15:28:42.626308 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2024-02-10T15:28:42.691735 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-02-10T15:28:42.696323 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-02-10T15:28:42.696419 #1]  INFO -- : > echo postgres installed!
I, [2024-02-10T15:28:42.699587 #1]  INFO -- : postgres installed!
I, [2024-02-10T15:28:42.707075 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-02-10T15:28:42.714049 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-02-10T15:28:42.720530 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-02-10T15:28:42.721086 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-02-10T15:28:42.721704 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-02-10T15:28:42.722827 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-02-10T15:28:42.726783 #1]  INFO -- :
I, [2024-02-10T15:28:42.727488 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-02-10T15:28:42.727999 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-02-10T15:28:42.728467 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-02-10T15:28:42.729000 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-02-10T15:28:42.729416 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-02-10T15:28:42.729808 #1]  INFO -- : > echo redis installed
I, [2024-02-10T15:28:42.732889 #1]  INFO -- : redis installed
I, [2024-02-10T15:28:42.733148 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-02-10T15:28:42.737749 #1]  INFO -- : logfile ""
I, [2024-02-10T15:28:42.738030 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-02-10T15:28:42.740854 #1]  INFO -- : > sleep 10
111:C 10 Feb 2024 15:28:42.747 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
111:C 10 Feb 2024 15:28:42.747 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=111, just started
111:C 10 Feb 2024 15:28:42.747 # Configuration loaded
111:M 10 Feb 2024 15:28:42.747 * monotonic clock: POSIX clock_gettime
111:M 10 Feb 2024 15:28:42.748 * Running mode=standalone, port=6379.
111:M 10 Feb 2024 15:28:42.748 # Server initialized
111:M 10 Feb 2024 15:28:42.748 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
111:M 10 Feb 2024 15:28:42.748 * Loading RDB produced by version 7.0.7
111:M 10 Feb 2024 15:28:42.748 * RDB age 214 seconds
111:M 10 Feb 2024 15:28:42.749 * RDB memory usage when created 274.89 Mb
111:M 10 Feb 2024 15:28:43.334 * Done loading RDB, keys loaded: 53401, keys expired: 84.
111:M 10 Feb 2024 15:28:43.334 * DB loaded from disk: 0.586 seconds
111:M 10 Feb 2024 15:28:43.334 * Ready to accept connections
I, [2024-02-10T15:28:52.744200 #1]  INFO -- :
I, [2024-02-10T15:28:52.744665 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-02-10T15:28:52.749537 #1]  INFO -- : thpoff is installed!
I, [2024-02-10T15:28:52.749776 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-02-10T15:28:52.829758 #1]  INFO -- :
I, [2024-02-10T15:28:52.829996 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-02-10T15:28:52.904820 #1]  INFO -- :
I, [2024-02-10T15:28:52.905265 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-02-10T15:28:52.980025 #1]  INFO -- :
I, [2024-02-10T15:28:52.980290 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-02-10T15:28:52.983859 #1]  INFO -- :
I, [2024-02-10T15:28:52.988059 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-02-10T15:28:52.995586 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-02-10T15:28:53.002789 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-02-10T15:28:53.009848 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-02-10T15:28:53.016652 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-02-10T15:28:53.023543 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-02-10T15:28:53.023741 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2024-02-10T15:28:53.023948 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-02-10T15:28:53.027127 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
138:C 10 Feb 2024 15:28:53.033 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
138:C 10 Feb 2024 15:28:53.033 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=138, just started
138:C 10 Feb 2024 15:28:53.033 # Configuration loaded
138:M 10 Feb 2024 15:28:53.033 * monotonic clock: POSIX clock_gettime
138:M 10 Feb 2024 15:28:53.034 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
138:M 10 Feb 2024 15:28:53.034 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (33715/33715), done.
I, [2024-02-10T15:28:57.414901 #1]  INFO -- : HEAD is now at 6ab1a19e9 DEV: Convert min_trust_level_to_allow_invite to groups (#24893)
I, [2024-02-10T15:28:57.415073 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-02-10T15:28:57.653225 #1]  INFO -- :
I, [2024-02-10T15:28:57.654133 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/0-drop-code
 - [deleted]             (none)     -> origin/bulk-button-class
 - [deleted]             (none)     -> origin/dependabot/bundler/excon-0.108.0
 - [deleted]             (none)     -> origin/dependabot/bundler/hashdiff-1.1.0
 - [deleted]             (none)     -> origin/dependabot/bundler/parallel-1.24.0
 - [deleted]             (none)     -> origin/dependabot/bundler/rubocop-discourse-3.6.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/drop-target-2.0.2
 - [deleted]             (none)     -> origin/dev/add-new-chat-metrics
 - [deleted]             (none)     -> origin/dev/allow-chat-mentions-to-have-several-notifications
 - [deleted]             (none)     -> origin/dev/convert-min-trust-level-to-create-tag-to-group
 - [deleted]             (none)     -> origin/dev/convert-min-trust-level-to-ignore-to-groups
 - [deleted]             (none)     -> origin/dev/rethink-mass-mentions-polymorphic
 - [deleted]             (none)     -> origin/feature/migrations-schema-generator
 - [deleted]             (none)     -> origin/fix-join-filter-upload
 - [deleted]             (none)     -> origin/fix-modal-flash-minor
 - [deleted]             (none)     -> origin/global-notice-reactive
 - [deleted]             (none)     -> origin/labeler
 - [deleted]             (none)     -> origin/low-ram-help
 - [deleted]             (none)     -> origin/multi-invite
 - [deleted]             (none)     -> origin/plugin-extra-js
 - [deleted]             (none)     -> origin/table-builder-modal-modifier
 - [deleted]             (none)     -> origin/wip_categories
 - [deleted]             (none)     -> origin/wizard-split
   6ab1a19e9..427e11b17  main                    -> origin/main
 * [new branch]          0-ember-bump            -> origin/0-ember-bump
 * [new branch]          0-event-helper          -> origin/0-event-helper
 * [new branch]          0-extend-native         -> origin/0-extend-native
 * [new branch]          0-fix-perf-watched-words -> origin/0-fix-perf-watched-words
 * [new branch]          0-rev                   -> origin/0-rev
 * [new branch]          add-api-for-forced-auth -> origin/add-api-for-forced-auth
 * [new branch]          api-image-wrapper       -> origin/api-image-wrapper
 * [new branch]          asciinema-iframe        -> origin/asciinema-iframe
 * [new branch]          bulk-select-dropdown-items -> origin/bulk-select-dropdown-items
 * [new branch]          convert-header-to-glimmer -> origin/convert-header-to-glimmer
 * [new branch]          decorator-transforms    -> origin/decorator-transforms
 * [new branch]          dependabot/bundler/omniauth-2.0.0 -> origin/dependabot/bundler/omniauth-2.0.0
 * [new branch]          dependabot/bundler/parallel_tests-4.4.0 -> origin/dependabot/bundler/parallel_tests-4.4.0
 * [new branch]          dev-convert-topic-map-expanded-widget-to-component -> origin/dev-convert-topic-map-expanded-widget-to-component
 * [new branch]          dev/check-whether-online-user-ids-may-be-memoized-between-job-runs -> origin/dev/check-whether-online-user-ids-may-be-memoized-between-job-runs
 * [new branch]          dev/drop-the-user-id-column-from-chat-mentions -> origin/dev/drop-the-user-id-column-from-chat-mentions
 + e0c0191bb...f4cb53e62 dev/dry-up-user-status-serializers -> origin/dev/dry-up-user-status-serializers  (forced update)
 * [new branch]          dev/experiment-theme-settings-free-ui -> origin/dev/experiment-theme-settings-free-ui
 * [new branch]          dev/make-admins-tl4-in-tests -> origin/dev/make-admins-tl4-in-tests
 * [new branch]          dev/promote-plugin-post-deploy-migrations -> origin/dev/promote-plugin-post-deploy-migrations
 * [new branch]          dev/proof-of-concept-rewriting-mentions-notification-logic -> origin/dev/proof-of-concept-rewriting-mentions-notification-logic
 * [new branch]          dev_category_order_database -> origin/dev_category_order_database
 * [new branch]          dev_test                -> origin/dev_test
 * [new branch]          dev_update_category_position -> origin/dev_update_category_position
 * [new branch]          extra-js-revert         -> origin/extra-js-revert
 * [new branch]          fast-edit-expand-regex  -> origin/fast-edit-expand-regex
   8780daeee..9c8a0eed3  feature/bookmark-menu-and-modal-redesign -> origin/feature/bookmark-menu-and-modal-redesign
 * [new branch]          feature/custom-date-range -> origin/feature/custom-date-range
 * [new branch]          feature/paste-upload-on-first-upload-input-templates -> origin/feature/paste-upload-on-first-upload-input-templates
 * [new branch]          feature_async_hashtags  -> origin/feature_async_hashtags
 * [new branch]          feature_async_load_colors -> origin/feature_async_load_colors
 * [new branch]          fix-empty-state-showing -> origin/fix-empty-state-showing
 * [new branch]          fix_category_chooser    -> origin/fix_category_chooser
 * [new branch]          fix_in_any_groups       -> origin/fix_in_any_groups
 * [new branch]          fix_reviewable_translation -> origin/fix_reviewable_translation
   7f2bdca65..4f57be1a8  generic-import-latest   -> origin/generic-import-latest
 * [new branch]          hijacks                 -> origin/hijacks
 * [new branch]          issue/change-max-image-megapixels-logic -> origin/issue/change-max-image-megapixels-logic
 * [new branch]          issue/run-admin-sidebar-init-after-logs-notice -> origin/issue/run-admin-sidebar-init-after-logs-notice
 * [new branch]          loic-rubocop-plugin-rules -> origin/loic-rubocop-plugin-rules
 + 90a3535b7...e6e64cfd5 migrations-convert      -> origin/migrations-convert  (forced update)
 * [new branch]          promote-migration-tweak -> origin/promote-migration-tweak
 * [new branch]          redesign-my-threads-index -> origin/redesign-my-threads-index
 * [new branch]          revert-25009-dev/convert-min-trust-to-allow-self-wiki-to-groups -> origin/revert-25009-dev/convert-min-trust-to-allow-self-wiki-to-groups
 * [new branch]          revert-bulk-topic-actions -> origin/revert-bulk-topic-actions
 * [new branch]          sidebar-above-outlet    -> origin/sidebar-above-outlet
 * [new branch]          site-logo-height        -> origin/site-logo-height
 * [new branch]          sort-chat-channels-by-activity -> origin/sort-chat-channels-by-activity
   d7f7f79b6..124aa9ac9  stable                  -> origin/stable
 * [new branch]          support-reset-bump-date-post-id -> origin/support-reset-bump-date-post-id
 * [new branch]          system-test-for-soft-load-search -> origin/system-test-for-soft-load-search
   6ab1a19e9..427e11b17  tests-passed            -> origin/tests-passed
 * [new branch]          tmp/move-notifiers-specs -> origin/tmp/move-notifiers-specs
 * [new branch]          unhide_lazy_load_categories -> origin/unhide_lazy_load_categories
 * [new branch]          universal-nonce         -> origin/universal-nonce
 * [new branch]          user-menu-full-name     -> origin/user-menu-full-name
 * [new branch]          user-native-class       -> origin/user-native-class
 * [new branch]          video-spike             -> origin/video-spike
 * [new branch]          virtual-scroll-list     -> origin/virtual-scroll-list
 t [tag update]          beta                    -> beta
 t [tag update]          latest-release          -> latest-release
 * [new tag]             v3.1.4                  -> v3.1.4
 * [new tag]             v3.1.5                  -> v3.1.5
 * [new tag]             v3.2.0                  -> v3.2.0
 * [new tag]             v3.2.0.beta4            -> v3.2.0.beta4
 * [new tag]             v3.2.0.beta5            -> v3.2.0.beta5
I, [2024-02-10T15:29:05.298288 #1]  INFO -- :
I, [2024-02-10T15:29:05.298479 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2024-02-10T15:29:17.577586 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2024-02-10T15:29:17.577734 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-02-10T15:29:17.590967 #1]  INFO -- :
I, [2024-02-10T15:29:17.591381 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-02-10T15:29:17.596099 #1]  INFO -- :
I, [2024-02-10T15:29:17.596291 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-02-10T15:29:17.600828 #1]  INFO -- :
I, [2024-02-10T15:29:17.601046 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-02-10T15:29:17.605605 #1]  INFO -- :
I, [2024-02-10T15:29:17.605842 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-02-10T15:29:17.610384 #1]  INFO -- :
I, [2024-02-10T15:29:17.610470 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-02-10T15:29:17.614685 #1]  INFO -- :
I, [2024-02-10T15:29:17.614865 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-02-10T15:29:17.619152 #1]  INFO -- :
I, [2024-02-10T15:29:17.619274 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-02-10T15:29:17.625132 #1]  INFO -- :
I, [2024-02-10T15:29:17.625306 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-02-10T15:29:17.631446 #1]  INFO -- :
I, [2024-02-10T15:29:17.631775 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-02-10T15:29:17.638516 #1]  INFO -- :
I, [2024-02-10T15:29:17.638721 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-02-10T15:29:17.644901 #1]  INFO -- :
I, [2024-02-10T15:29:17.645089 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2024-02-10T15:29:17.651643 #1]  INFO -- :
I, [2024-02-10T15:29:17.651774 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-02-10T15:29:17.657812 #1]  INFO -- :
I, [2024-02-10T15:29:17.657994 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-02-10T15:29:17.804116 #1]  INFO -- :
I, [2024-02-10T15:29:17.804276 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-02-10T15:29:17.807583 #1]  INFO -- :
I, [2024-02-10T15:29:17.807841 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-02-10T15:29:17.808087 #1]  INFO -- : > cd /var/www/discourse && sudo apt-get install wget ca-certificates
I, [2024-02-10T15:29:17.856331 #1]  INFO -- : Reading package lists...
Building dependency tree...
Reading state information...
ca-certificates is already the newest version (20210119).
wget is already the newest version (1.21-1+deb11u1).
The following packages were automatically installed and are no longer required:
  ruby-minitest ruby-net-telnet ruby-power-assert ruby-test-unit ruby-xmlrpc
  rubygems-integration
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I, [2024-02-10T15:29:17.856652 #1]  INFO -- : > cd /var/www/discourse && wget --quiet -O - https://www.postgresql.org/media/keys/ACCC4CF8.asc | sudo apt-key add -
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
I, [2024-02-10T15:29:19.269067 #1]  INFO -- : OK
I, [2024-02-10T15:29:19.269324 #1]  INFO -- : > cd /var/www/discourse && sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt/ `lsb_release -cs`-pgdg main" >> /etc/apt/sources.list.d/pgdg.list'
I, [2024-02-10T15:29:19.318378 #1]  INFO -- :
I, [2024-02-10T15:29:19.318652 #1]  INFO -- : > cd /var/www/discourse && apt-get update
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list.d/pgdg.list:1 and /etc/apt/sources.list.d/postgres.list:1
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/pgdg.list:1 and /etc/apt/sources.list.d/postgres.list:1
I, [2024-02-10T15:29:21.808432 #1]  INFO -- : Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
Get:2 http://deb.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Get:4 http://deb.debian.org/debian bullseye-backports InRelease [49.0 kB]
Get:5 http://deb.debian.org/debian bullseye/main amd64 Packages [8,068 kB]
Get:6 http://apt.postgresql.org/pub/repos/apt bullseye-pgdg InRelease [123 kB]
Get:7 https://dl.yarnpkg.com/debian stable InRelease [17.1 kB]
Get:8 https://deb.nodesource.com/node_18.x bullseye InRelease [4,586 B]
Get:9 http://deb.debian.org/debian-security bullseye-security/main amd64 Packages [267 kB]
Get:10 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [18.8 kB]
Get:11 http://deb.debian.org/debian bullseye-backports/main amd64 Packages [403 kB]
Get:12 https://dl.yarnpkg.com/debian stable/main amd64 Packages [10.9 kB]
Get:13 https://dl.yarnpkg.com/debian stable/main all Packages [10.9 kB]
Get:14 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages [776 B]
Get:15 http://apt.postgresql.org/pub/repos/apt bullseye-pgdg/main amd64 Packages [306 kB]
Fetched 9,487 kB in 2s (5,132 kB/s)
I, [2024-02-10T15:29:21.808949 #1]  INFO -- : > cd /var/www/discourse && apt-get -y install -y postgresql-server-dev-13
debconf: delaying package configuration, since apt-utils is not installed
I, [2024-02-10T15:30:08.156689 #1]  INFO -- : Reading package lists...
Use 'apt autoremove' to remove them.
The following additional packages will be installed:
  binfmt-support clang-13 lib32gcc-s1 lib32stdc++6 libc-dev-bin libc6
  libc6-dev libc6-i386 libclang-common-13-dev libclang-cpp13 libclang1-13
  libgc1 libllvm13 libobjc-10-dev libobjc4 libpfm4 libpipeline1 libz3-dev
  llvm-13 llvm-13-dev llvm-13-linker-tools llvm-13-runtime llvm-13-tools
  python3-pkg-resources python3-pygments python3-yaml
Suggested packages:
  clang-13-doc glibc-doc llvm-13-doc python3-setuptools python-pygments-doc
  ttf-bitstream-vera
Recommended packages:
  libnss-nis libnss-nisplus
The following NEW packages will be installed:
  binfmt-support clang-13 lib32gcc-s1 lib32stdc++6 libc6-i386
  libclang-common-13-dev libclang-cpp13 libclang1-13 libgc1 libllvm13
  libobjc-10-dev libobjc4 libpfm4 libpipeline1 libz3-dev llvm-13 llvm-13-dev
  llvm-13-linker-tools llvm-13-runtime llvm-13-tools postgresql-server-dev-13
The following packages will be upgraded:
  libc-dev-bin libc6 libc6-dev
3 upgraded, 24 newly installed, 0 to remove and 36 not upgraded.
Need to get 99.2 MB of archives.
After this operation, 619 MB of additional disk space will be used.
Get:1 http://deb.debian.org/debian bullseye/main amd64 libc6-dev amd64 2.31-13+deb11u8 [2,361 kB]
Get:2 http://apt.postgresql.org/pub/repos/apt bullseye-pgdg/main amd64 postgresql-server-dev-13 amd64 13.14-1.pgdg110+1 [1,043 kB]
Get:3 http://deb.debian.org/debian bullseye/main amd64 libc-dev-bin amd64 2.31-13+deb11u8 [276 kB]
Get:4 http://deb.debian.org/debian bullseye/main amd64 libc6 amd64 2.31-13+deb11u8 [2,823 kB]
Get:5 http://deb.debian.org/debian bullseye/main amd64 libpipeline1 amd64 1.5.3-1 [34.3 kB]
Get:6 http://deb.debian.org/debian bullseye/main amd64 binfmt-support amd64 2.2.1-1+deb11u1 [66.8 kB]
Get:7 http://deb.debian.org/debian bullseye/main amd64 libllvm13 amd64 1:13.0.1-6~deb11u1 [20.1 MB]
Get:8 http://deb.debian.org/debian bullseye/main amd64 libclang-cpp13 amd64 1:13.0.1-6~deb11u1 [10.7 MB]
Get:9 http://deb.debian.org/debian bullseye/main amd64 libgc1 amd64 1:8.0.4-3 [239 kB]
Get:10 http://deb.debian.org/debian bullseye/main amd64 libobjc4 amd64 10.2.1-6 [41.8 kB]
Get:11 http://deb.debian.org/debian bullseye/main amd64 libobjc-10-dev amd64 10.2.1-6 [170 kB]
Get:12 http://deb.debian.org/debian bullseye/main amd64 libc6-i386 amd64 2.31-13+deb11u8 [2,615 kB]
Get:13 http://deb.debian.org/debian bullseye/main amd64 lib32gcc-s1 amd64 10.2.1-6 [49.4 kB]
Get:14 http://deb.debian.org/debian bullseye/main amd64 lib32stdc++6 amd64 10.2.1-6 [510 kB]
Get:15 http://deb.debian.org/debian bullseye/main amd64 libclang-common-13-dev amd64 1:13.0.1-6~deb11u1 [5,602 kB]
Get:16 http://deb.debian.org/debian bullseye/main amd64 llvm-13-linker-tools amd64 1:13.0.1-6~deb11u1 [1,253 kB]
Get:17 http://deb.debian.org/debian bullseye/main amd64 libclang1-13 amd64 1:13.0.1-6~deb11u1 [6,187 kB]
Get:18 http://deb.debian.org/debian bullseye/main amd64 clang-13 amd64 1:13.0.1-6~deb11u1 [123 kB]
Get:19 http://deb.debian.org/debian bullseye/main amd64 libpfm4 amd64 4.11.1+git32-gd0b85fb-1 [286 kB]
Get:20 http://deb.debian.org/debian bullseye/main amd64 libz3-dev amd64 4.8.10-1 [90.8 kB]
Get:21 http://deb.debian.org/debian bullseye/main amd64 llvm-13-runtime amd64 1:13.0.1-6~deb11u1 [265 kB]
Get:22 http://deb.debian.org/debian bullseye/main amd64 llvm-13 amd64 1:13.0.1-6~deb11u1 [11.0 MB]
Get:23 http://deb.debian.org/debian bullseye/main amd64 python3-pkg-resources all 52.0.0-4 [190 kB]
Get:24 http://deb.debian.org/debian bullseye/main amd64 python3-pygments all 2.7.1+dfsg-2.1 [657 kB]
Get:25 http://deb.debian.org/debian bullseye/main amd64 python3-yaml amd64 5.3.1-5 [138 kB]
Get:26 http://deb.debian.org/debian bullseye/main amd64 llvm-13-tools amd64 1:13.0.1-6~deb11u1 [421 kB]
Get:27 http://deb.debian.org/debian bullseye/main amd64 llvm-13-dev amd64 1:13.0.1-6~deb11u1 [31.9 MB]
Fetched 99.2 MB in 13s (7,385 kB/s)
(Reading database ... 44274 files and directories currently installed.)
Preparing to unpack .../libc6-dev_2.31-13+deb11u8_amd64.deb ...
Unpacking libc6-dev:amd64 (2.31-13+deb11u8) over (2.31-13+deb11u7) ...
Preparing to unpack .../libc-dev-bin_2.31-13+deb11u8_amd64.deb ...
Unpacking libc-dev-bin (2.31-13+deb11u8) over (2.31-13+deb11u7) ...
Preparing to unpack .../libc6_2.31-13+deb11u8_amd64.deb ...
Unpacking libc6:amd64 (2.31-13+deb11u8) over (2.31-13+deb11u7) ...
Setting up libc6:amd64 (2.31-13+deb11u8) ...
Selecting previously unselected package libpipeline1:amd64.
Preparing to unpack .../00-libpipeline1_1.5.3-1_amd64.deb ...
Unpacking libpipeline1:amd64 (1.5.3-1) ...
Selecting previously unselected package binfmt-support.
Preparing to unpack .../01-binfmt-support_2.2.1-1+deb11u1_amd64.deb ...
Unpacking binfmt-support (2.2.1-1+deb11u1) ...
Selecting previously unselected package libllvm13:amd64.
Preparing to unpack .../02-libllvm13_1%3a13.0.1-6~deb11u1_amd64.deb ...
Unpacking libllvm13:amd64 (1:13.0.1-6~deb11u1) ...
Selecting previously unselected package libclang-cpp13.
Preparing to unpack .../03-libclang-cpp13_1%3a13.0.1-6~deb11u1_amd64.deb ...
Unpacking libclang-cpp13 (1:13.0.1-6~deb11u1) ...
Selecting previously unselected package libgc1:amd64.
Preparing to unpack .../04-libgc1_1%3a8.0.4-3_amd64.deb ...
Unpacking libgc1:amd64 (1:8.0.4-3) ...
Selecting previously unselected package libobjc4:amd64.
Preparing to unpack .../05-libobjc4_10.2.1-6_amd64.deb ...
Unpacking libobjc4:amd64 (10.2.1-6) ...
Selecting previously unselected package libobjc-10-dev:amd64.
Preparing to unpack .../06-libobjc-10-dev_10.2.1-6_amd64.deb ...
Unpacking libobjc-10-dev:amd64 (10.2.1-6) ...
Selecting previously unselected package libc6-i386.
Preparing to unpack .../07-libc6-i386_2.31-13+deb11u8_amd64.deb ...
Unpacking libc6-i386 (2.31-13+deb11u8) ...
Selecting previously unselected package lib32gcc-s1.
Preparing to unpack .../08-lib32gcc-s1_10.2.1-6_amd64.deb ...
Unpacking lib32gcc-s1 (10.2.1-6) ...
Selecting previously unselected package lib32stdc++6.
Preparing to unpack .../09-lib32stdc++6_10.2.1-6_amd64.deb ...
Unpacking lib32stdc++6 (10.2.1-6) ...
Selecting previously unselected package libclang-common-13-dev.
Preparing to unpack .../10-libclang-common-13-dev_1%3a13.0.1-6~deb11u1_amd64.deb ...
Unpacking libclang-common-13-dev (1:13.0.1-6~deb11u1) ...
Selecting previously unselected package llvm-13-linker-tools.
Preparing to unpack .../11-llvm-13-linker-tools_1%3a13.0.1-6~deb11u1_amd64.deb ...
Unpacking llvm-13-linker-tools (1:13.0.1-6~deb11u1) ...
Selecting previously unselected package libclang1-13.
Preparing to unpack .../12-libclang1-13_1%3a13.0.1-6~deb11u1_amd64.deb ...
Unpacking libclang1-13 (1:13.0.1-6~deb11u1) ...
Selecting previously unselected package clang-13.
Preparing to unpack .../13-clang-13_1%3a13.0.1-6~deb11u1_amd64.deb ...
Unpacking clang-13 (1:13.0.1-6~deb11u1) ...
Selecting previously unselected package libpfm4:amd64.
Preparing to unpack .../14-libpfm4_4.11.1+git32-gd0b85fb-1_amd64.deb ...
Unpacking libpfm4:amd64 (4.11.1+git32-gd0b85fb-1) ...
Selecting previously unselected package libz3-dev:amd64.
Preparing to unpack .../15-libz3-dev_4.8.10-1_amd64.deb ...
Unpacking libz3-dev:amd64 (4.8.10-1) ...
Selecting previously unselected package llvm-13-runtime.
Preparing to unpack .../16-llvm-13-runtime_1%3a13.0.1-6~deb11u1_amd64.deb ...
Unpacking llvm-13-runtime (1:13.0.1-6~deb11u1) ...
Selecting previously unselected package llvm-13.
Preparing to unpack .../17-llvm-13_1%3a13.0.1-6~deb11u1_amd64.deb ...
Unpacking llvm-13 (1:13.0.1-6~deb11u1) ...
Selecting previously unselected package python3-pkg-resources.
Preparing to unpack .../18-python3-pkg-resources_52.0.0-4_all.deb ...
Unpacking python3-pkg-resources (52.0.0-4) ...
Selecting previously unselected package python3-pygments.
Preparing to unpack .../19-python3-pygments_2.7.1+dfsg-2.1_all.deb ...
Unpacking python3-pygments (2.7.1+dfsg-2.1) ...
Selecting previously unselected package python3-yaml.
Preparing to unpack .../20-python3-yaml_5.3.1-5_amd64.deb ...
Unpacking python3-yaml (5.3.1-5) ...
Selecting previously unselected package llvm-13-tools.
Preparing to unpack .../21-llvm-13-tools_1%3a13.0.1-6~deb11u1_amd64.deb ...
Unpacking llvm-13-tools (1:13.0.1-6~deb11u1) ...
Selecting previously unselected package llvm-13-dev.
Preparing to unpack .../22-llvm-13-dev_1%3a13.0.1-6~deb11u1_amd64.deb ...
Unpacking llvm-13-dev (1:13.0.1-6~deb11u1) ...
Selecting previously unselected package postgresql-server-dev-13.
Preparing to unpack .../23-postgresql-server-dev-13_13.14-1.pgdg110+1_amd64.deb ...
Unpacking postgresql-server-dev-13 (13.14-1.pgdg110+1) ...
Setting up python3-pkg-resources (52.0.0-4) ...
Setting up libpipeline1:amd64 (1.5.3-1) ...
Setting up libz3-dev:amd64 (4.8.10-1) ...
Setting up python3-yaml (5.3.1-5) ...
Setting up python3-pygments (2.7.1+dfsg-2.1) ...
Setting up libpfm4:amd64 (4.11.1+git32-gd0b85fb-1) ...
Setting up binfmt-support (2.2.1-1+deb11u1) ...
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Setting up libllvm13:amd64 (1:13.0.1-6~deb11u1) ...
Setting up libgc1:amd64 (1:8.0.4-3) ...
Setting up llvm-13-runtime (1:13.0.1-6~deb11u1) ...
Setting up libc6-i386 (2.31-13+deb11u8) ...
Setting up libc-dev-bin (2.31-13+deb11u8) ...
Setting up libobjc4:amd64 (10.2.1-6) ...
Setting up llvm-13-linker-tools (1:13.0.1-6~deb11u1) ...
Setting up llvm-13-tools (1:13.0.1-6~deb11u1) ...
Setting up libclang1-13 (1:13.0.1-6~deb11u1) ...
Setting up lib32gcc-s1 (10.2.1-6) ...
Setting up lib32stdc++6 (10.2.1-6) ...
Setting up libclang-cpp13 (1:13.0.1-6~deb11u1) ...
Setting up libobjc-10-dev:amd64 (10.2.1-6) ...
Setting up libc6-dev:amd64 (2.31-13+deb11u8) ...
Setting up libclang-common-13-dev (1:13.0.1-6~deb11u1) ...
Setting up clang-13 (1:13.0.1-6~deb11u1) ...
Setting up llvm-13 (1:13.0.1-6~deb11u1) ...
Setting up llvm-13-dev (1:13.0.1-6~deb11u1) ...
Setting up postgresql-server-dev-13 (13.14-1.pgdg110+1) ...
Processing triggers for libc-bin (2.31-13+deb11u7) ...
I, [2024-02-10T15:30:08.158087 #1]  INFO -- : > cd /var/www/discourse/tmp && git clone https://github.com/neondatabase/pg_embedding.git
Cloning into 'pg_embedding'...
I, [2024-02-10T15:30:14.064772 #1]  INFO -- :
I, [2024-02-10T15:30:14.065159 #1]  INFO -- : > cd /var/www/discourse/tmp/pg_embedding && make PG_CONFIG=/usr/lib/postgresql/13/bin/pg_config
make: /usr/bin/clang-11: No such file or directory
make: *** [/usr/lib/postgresql/13/lib/pgxs/src/makefiles/../../src/Makefile.global:1083: embedding.bc] Error 127
I, [2024-02-10T15:30:16.015321 #1]  INFO -- : gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -g -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -fno-omit-frame-pointer -Ofast -fPIC -I. -I./ -I/usr/include/postgresql/13/server -I/usr/include/postgresql/internal  -Wdate-time -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2   -c -o embedding.o embedding.c
g++ -Wall -Wpointer-arith -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wformat-security -fno-strict-aliasing -fwrapv -g -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -std=c++11 -fPIC -I. -I./ -I/usr/include/postgresql/13/server -I/usr/include/postgresql/internal  -Wdate-time -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2   -c -o hnswalg.o hnswalg.cpp
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -g -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -fno-omit-frame-pointer -Ofast -fPIC -I. -I./ -I/usr/include/postgresql/13/server -I/usr/include/postgresql/internal  -Wdate-time -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2   -c -o distfunc.o distfunc.c
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Werror=vla -Wendif-labels -Wmissing-format-attribute -Wimplicit-fallthrough=3 -Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-truncation -Wno-stringop-truncation -g -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -fno-omit-frame-pointer -Ofast -fPIC -shared -o embedding.so embedding.o hnswalg.o distfunc.o -lstdc++ -L/usr/lib/x86_64-linux-gnu -Wl,-z,relro -Wl,-z,now -L/usr/lib/llvm-11/lib  -Wl,--as-needed
/usr/bin/clang-11 -Wno-ignored-attributes -fno-strict-aliasing -fwrapv -Wno-unused-command-line-argument -O2  -I. -I./ -I/usr/include/postgresql/13/server -I/usr/include/postgresql/internal  -Wdate-time -D_FORTIFY_SOURCE=2 -D_GNU_SOURCE -I/usr/include/libxml2  -flto=thin -emit-llvm -c -o embedding.bc embedding.c
I, [2024-02-10T15:30:16.016368 #1]  INFO -- : Terminating async processes
I, [2024-02-10T15:30:16.016455 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2024-02-10T15:30:16.016506 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 111
111:signal-handler (1707579016) Received SIGTERM scheduling shutdown...
2024-02-10 15:30:16.016 UTC [42] LOG:  received fast shutdown request
2024-02-10 15:30:16.026 UTC [42] LOG:  aborting any active transactions
2024-02-10 15:30:16.032 UTC [42] LOG:  background worker "logical replication launcher" (PID 51) exited with exit code 1
2024-02-10 15:30:16.033 UTC [46] LOG:  shutting down
111:M 10 Feb 2024 15:30:16.072 # User requested shutdown...
111:M 10 Feb 2024 15:30:16.073 * Saving the final RDB snapshot before exiting.
2024-02-10 15:30:16.075 UTC [42] LOG:  database system is shut down
111:M 10 Feb 2024 15:30:17.044 * DB saved on disk
111:M 10 Feb 2024 15:30:17.044 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse/tmp/pg_embedding && make PG_CONFIG=/usr/lib/postgresql/13/bin/pg_config failed with return #<Process::Status: pid 1488 exit 2>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home/tmp/pg_embedding", "cmd"=>["make PG_CONFIG=/usr/lib/postgresql/13/bin/pg_config"]}
bootstrap failed with exit code 2
bd5ac450b788010fb0ab1bd159ceb14e5f84b661a8d21b25eb838ff4541ab308
(¿Es esta una instalación de desarrollo?)
No, esta es una instalación estándar.
Hmm. ¿Qué plugins, hooks o comandos run-after tienes en tu app.yml?
Hooks:
## Esto es para que discourse-chatbot funcione correctamente - 9pfs
## Ver https://meta.discourse.org/t/discourse-chatbot-now-smarter-than-chatgpt/256652/382?u=hello-smile6 para más información.
    - exec:
        cd: $home
        cmd:
          - sudo apt-get install wget ca-certificates
    - exec:
        cd: $home
        cmd:
          - wget --quiet -O - https://www.postgresql.org/media/keys/ACCC4CF8.asc | sudo apt-key add -
    - exec:
        cd: $home
        cmd:
          - sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt/ `lsb_release -cs`-pgdg main" >> /etc/apt/sources.list.d/pgdg.list'
    - exec:
        cd: $home
        cmd:
          - apt-get update
    - exec:
        cd: $home
        cmd:
          - apt-get -y install -y postgresql-server-dev-13
    - exec:
        cd: $home/tmp
        cmd:
          - git clone https://github.com/neondatabase/pg_embedding.git
    - exec:
        cd: $home/tmp/pg_embedding
        cmd:
          - make PG_CONFIG=/usr/lib/postgresql/13/bin/pg_config
    - exec:
        cmd:
          - make PG_CONFIG=/usr/lib/postgresql/13/bin/pg_config install
    - exec:
        cd: $home
        cmd:
          - su postgres -c 'psql discourse -c "create extension if not exists embedding;"'
Plugins:
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-automation.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-calendar.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-templates.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-assign.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-user-notes.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-data-explorer.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-topic-voting.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-ai.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-login-with-amazon.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-linkedin-auth.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-microsoft-auth.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-docs.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-github.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-solved.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-cakeday.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-reactions.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-gamification.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-affiliate.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-apple-auth.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-akismet.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-rss-polling.git
          #- sudo -E -u discourse git clone https://github.com/discourse/discourse-subscriptions.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-yearly-review.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-math.git
          #- sudo -E -u discourse git clone https://github.com/discourse/discourse-patreon.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-activity-pub.git
          #- git clone https://github.com/discourse/discourse-templates.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-whos-online.git
          - sudo -E -u discourse git clone https://github.com/discourse/discourse-shared-edits.git
          #- sudo -E -u discourse git clone https://github.com/discourse/discourse-animated-avatars.git
After commands:
  - replace:
     filename: "/etc/nginx/conf.d/discourse.conf"
     to: |
       listen 80;
       set_real_ip_from 192.168.1.0/16;
  - replace:
     to: |
       listen 443 ssl http2;
Esas líneas que podrías haber necesitado para compilar pgembedding para Chatbot ahora son innecesarias, ya que ahora usa pgvector, que debería estar listo para usar.
¡Y esa fue la causa del error, gracias!
