Impossibile rimuovere il timer per l'eliminazione delle risposte in un argomento
Trying to remove a “Delete Replies after days” topic timer from a topic fails:
curl 'https://meta.discourse.org/t/151236/timer'  --data-raw 'time=&status_type=delete_replies'
{"errors":["param is missing or the value is empty: duration"]}
4 Mi Piace
Also have this problem. Neither way works to remove it except to refresh page?
Should we assign this @eviltrout?
2 Mi Piace
I think this should be fixed by:
I have asked a review from @vinothkannans as he worked on this. I feel like the spec here should be reworked, we currently randomly test on few types, but we should have a context for each type which would test create/update/delete.
What was happening here, is that we were requiring a duration for delete_replies type even when removing it, when we actually rely on the fact that duration is nil to remove the timer.
8 Mi Piace
@Falco this is merged, let me know how it goes for you when you can test it.
3 Mi Piace
