Cant signup (Full Name input missing?)
Our forum (https://forum.codingpirates.dk) could not accept new signups because I had “full name required” was enabled, but the signup form does not contain the full name input field.
Custom fields is also in use, maybe this collides ?
Solved it for now by disabling the requirement, but I would really have this requirement back.
What do you have the following settings set to?
I have them setup like this now:
Enabling full name required breaks signup (blue button is disabled no matter what)
Okay, that seems to be because you disabled enable names, to have full name required you must also have enable names enabled.
Hmm ok.
I have require because I want to be able as admin to police a bit who signs up, but users should not know each others real names.
But yes, you are right - it resolves the problem. Full name input in signup form can be hidden but still required.
