Hi. I’ve searched around but couldn’t find an easy way (via the admin page) to set the name field as required or to remove it so I can create a custom one that is required.
Sorry if this is a basic question, I am at a loss.
Is http://example.com/admin/customize/user_fields what you’re after?
I’ve worked out how to create custom ones and making them compulsory fields, but I cannot work out how to make the name field compulsory or remove it.
Currently if I create a name field and make it ‘required’, I end up with two name fields in the sign up form.
EDIT: I’m talking about the default sign-up name field that ships with vanilla discourse.
EDIT2: Ideally I would just like to know how to make that name field required.
Ah - I see what you’re getting at.
I’ve not seen anything in /admin to do that, and I highly suspect it’s not (currently) possible.
I suggest either making a request in, or moving this topic to, (probably) Feature
Ok, I’ve just moved it.
Thanks for your help so far.
EDIT: What a wonderful system Discourse is. Thanks a million to the devs and staff. It is an incredibly well thought out platform.
@neil can you add to your list a checkbox to make full name a required field at user signup time?
Wonderful. Thanks @codinghorror and @neil!
Will be curious how this effects people who are invited to the forum.
It’s on my list! Will get to it soon.
I added this feature today.
There’s a checkbox in the Users section of the settings called “full name required”. Give it a try!
