Alleen de berichten in een onderwerp vastleggen
I saw this thread but I’m not sure there can’t be an easier way.
Our board has a topic with 38 great posts in it.
I want to capture just the posts and put them in a word processor.
If I select all and copy, I get the posts but an enormous amount of junk as well. Same with a PDF.
Forgive me if I missed an easy way mentioned somewhere else. Thanks.
Try doing a control-of to print the page dns copying that.
thanks Jay
could you type that more slowly? I think it got garbled…
I’ll let Jay clarify, but I wanted to ask if the raw markdown path works for you:
Right now if I visit https://meta.discourse.org/raw/246401/ I can copy the following:
Seth_Godin | 2022-11-22 12:46:25 UTC | #1
I saw this [thread](https://meta.discourse.org/t/how-to-export-comments-under-a-specific-post/230008) but I'm not sure there can't be an easier way.
![Screenshot 2022-11-22 at 7.44.17 AM|426x356](upload://gJl4t4RXeO85M0FQzH6oY7kiGD5.jpeg)
pfaffman | 2022-11-22 22:55:05 UTC | #2
Seth_Godin | 2022-11-22 23:24:41 UTC | #5
thanks Jay
could you type that more slowly? I think it got garbled...
Is there other information you want included/omitted from there? :slight_smile:
That’s control p, as in print this page.
this is EXACTLY what I needed
thank you
