Pagina principale della categoria come predefinita?
Yes, I also realized that showing the category page by default might provide better orientation for new users and changed my homepage.
When read @HAWK’s statement, I’m wondering: if that is indeed a general “rule”, then wouldn’t it make sense to set the category page as default homepage for new forums?
Disclaimer: I’m assuming that there is a default homepage. I don’t remember whether this is something you are asked to specific in the setup process, but even if it is, there’ d seem to be something that pushed me towards choosing “Latest” as my homepage. (As a side note: it is also somewhat difficult to find how to change the homepage)
1 Mi Piace
The easiest way is to rerun the wizard.
1 Mi Piace
I’m not sure if that is “easier” than changing the order of your top menu items. If you know that this is what you have to do, I’d say that’s the easiest. But if you don’t know what to do, searching the settings will point you neither to the wizard nor to the order of the items in the top menu.
Suggestion: perhaps it would help to change the help text for the top menu settings from this:
to: “Determine which items appear in the homepage navigation and in what order (the first item is the default homepage). Example: latest|…”
But the more user friendly solution would be to add a site setting “default home page”, simple because the way things are now, it’s a bit of a nuisance that you have to remove all the items in order to change the first one.
14 Mi Piace
We are more likely to delete that setting altogether.
1 Mi Piace
You mean the top menu site setting?
Hey guys,
I would like to edit our discourse channel as to make the categories the default for the homepage, just like here:
Currently, the default for the home page is “Latest”.
How can I do that?
Best,
Vlad
Re-run the wizard (example.com/wizard) and choose Categories and Latest Topics.
13 Mi Piace
Thank you! It worked.
1 Mi Piace
Can you elaborate?
I am about to use the strategy mentioned here which is to set the default homepage to Categories (I assume by re-ordering that list, which is a little confusing), but then setting the Logo to link to Latest. This enables new users to encounter the Categories, but generally to after that be encountering latest.
If this is to be removed, can you explain how we could address the given concerns? Or link to discussion about this.
thanks!
That global setting is still active however it’s more simple if you choose the homepage when you run the wizard the first time (and subsequently). Whether the setting is hidden or not for you is irrelevant (you can always use the wizard).
You can certainly change the link to the logo.
I also want to remember you that now the users can choose the default page from the preferences on the user profile:
4 Mi Piace
È mai stata presa in considerazione un’impaginazione diversa della homepage per desktop e mobile? O, in quanto nuovo utente, ho semplicemente non trovato un’impostazione che lo permetta?
Ho pensato di impostare il desktop in modalità ‘categoria - ultimi’, se solo ci fosse un modo per far sì che il mobile mostri di default solo gli ultimi.
1 Mi Piace
4 Mi Piace
Esiste anche un componente del tema per forzare la homepage mobile a essere diversa da quella desktop:
ma ricorda che i tuoi utenti non potranno sovrascrivere questa modifica dal loro profilo utente.
7 Mi Piace
Questo ha fatto al caso mio, grazie!
Come ho detto prima, esiste un componente tema per questo
5 Mi Piace
Ottimo! Grazie per avermi indicato questa impostazione.
@codinghorror Mi mancherebbe questa impostazione se venisse rimossa… perché dovresti?
Ho appena cambiato la visualizzazione del mio sito in quella per categorie. Rimane così per l’utente finché non effettua l’accesso, momento in cui passa alla visualizzazione più recente.
Esiste un modo per forzare tutte le preferenze degli utenti alla visualizzazione predefinita una sola volta? Forse c’è un comando SQL da eseguire?
Grazie.
L’utente può sovrascrivere questa impostazione tramite /my/preferences/interface – nota dove è indicato “Pagina Iniziale Predefinita”
Sì, grazie. Ma è difficile educare gli utenti, nel nostro tipo di forum.
Un comando per aggiornare una sola volta sarebbe molto utile.
Oggi ho fatto questo per utilizzarlo con il componente tema Kanban Board.
3 Mi Piace
