Change 'Solved' icon and 'Solution' button
Hello! I’m curious to know 2 things:
  1. Is there a way we can change the icon and text based on unselected/selected responses? For example:
    A response that is not marked as a solution will show this.
    While a response marked as a solution will show this.
  2. Can admins/mods have the same view as OP (like above) when using this plugin? I’m curious to understand the decision behind removing the helper text when viewing a topic that the admin/mod did not create.
Thanks! :slight_smile:
@DorisHo
you could change the wording in settings > customize, find the string, change the wording there.
I think both accepted/unaccepted use the same one (js.solved.solution) so I’m not sure you can have different ones for each just based on the customise text option?
For this, I think this is to keep a cleaner UI for admins and mods. Once you know what the icon does, I think there’s less need for the explainer label. This way you can have it on every post and it not be too obtrusive.
