Changing timestamp of topic replies - Easier way?
The discussion revolves around the desire to change the timestamp of individual replies within a topic in Discourse, particularly for an archival project involving manually transferring content from Archive.org. Brentnauer notes that while the topic’s timestamp can be adjusted via the UI, there’s no equivalent functionality for replies, and modifying dates via the CLI is cumbersome. pfaffman suggests using an import tool, but Brentnauer clarifies the content is being manually copied, making such tools impractical. codinghorror confirms CLI use is necessary, while ErikMH proposes a workaround: creating new topics for each reply, adjusting timestamps, and moving them into the original thread. Jack51 supports the idea of extending the existing timestamp editing feature to replies, acknowledging the complexity but suggesting it might be feasible.
I see that there’s now a way to change the topic’s timestamp through the UI and that it does a relative timestamp update for all following posts. That’s awesome!
However, I’m looking for a way to specify a timestamp for replies WITHIN a topic. I’m wanting to do an archival/restoration project for an old forum that’s since been deleted and will be manually pulling post text from Archive.org. Having to muck around in the CLI is going to make using Discourse unfeasible.
Is there any way to extend that functionality to subsequent replies within a topic, or at least a way to make mucking around in the CLI not such a tedious project? Hoping there’s something easier than the last time I checked: Editing post date?
Sounds like what you need is an importer that will maintain the time stamps.
No, the content is being brought over manually from Archive.org - There’s nothing to import.
What I’m hoping for is a plugin or something to add the date change UI that already exists for the first post in the thread to all subsequent replies.
I was thinking that code would either import a copy of what is on archive.org or would work from a downloaded copy.
Delayed response - we moved across the country!
No, the posts would be copy/pasted over manually as there’s a lot of attachments and a lot of cleanup/reorganizing to do.
What I’m after is a way to change the date of ANY post to ANY date, without it also offsetting the relative date for every other post in the thread.
You’re really going to need to use the command line for this sort of thing.
إذا كنت تقوم بذلك يدويًا على أي حال، فيمكنك:
  1. إضافة كل رد كموضوع جديد مستقل
  2. تصحيح تاريخه ووقته يدويًا
  3. نقل الرد إلى “الموضوع الموجود” — أي جعله ردًا على المنشور الأصلي
عمل شاق، لكنه ينجح.
لقد صادفت أيضًا حالة استخدام لهذه الميزة، لذا أتابع لمعرفة مدى صعوبة تمكين تعديل تاريخ المنشور.
أتخيل أن إضافة نفس الزر/الوظيفة الموجودة حاليًا تحت رمز “المفتاح” للموضوع يمكن تكرارها إلى حد كبير تحت رمز “المفتاح” للمنشور… لكنني لا أزال غير ملم تمامًا بالسحر الداخلي لمنصة Discourse، لذا لا أدرك أي تعقيدات قد ينشئها ذلك.
إريك - طريقتك تعمل… لكنها تتطلب جهدًا يدويًا كبيرًا عند التوسع!
ما هي آراؤكم؟
