Changing URL of "Guidelines" page from /faq to /guidelines
The discussion revolves around changing the URL of the “Guidelines” page from /faq to /guidelines. Jonathan5 asks if a previously mentioned method is still the best way to achieve this. The method involves setting the faq url to /guidelines and hiding the original tab using CSS. Lilly suggests a CSS solution to hide the green-bordered Guidelines tab, which Canapin confirms as a viable solution in the absence of a more straightforward method. The consensus is that the original method, combined with Lilly’s CSS solution, is still the best way to change the Guidelines page’s URL.
Continuing the discussion from Possible to change URL for /faq page?:
Is the method mentioned here still the best way of changing the Guidelines page’s URL from /faq to /guidelines?
(It adds a second tab called Guidelines by setting faq url to /guidelines, and hides the original tab using CSS.)
maybe have a look at this first:
Thanks. I think that just explains the problem (better than I have) rather than supplies a solution.
To restate the problem using the screenshots above – I’d like to get rid of the green-bordered Guidelines tab completely (I can customise the name of the blue-bordered tab so that it says “Guidelines”).
Or some other way of having a “Guidelines” tab have the URL /guidelines instead of /faq.
heh i will not soon forget that faq guidelines puzzle topic :laughing:
i can probably figure out how to hide it but i’d have to enable it do it or find a site that has one…
does this work?
.nav-pills .nav-item-guidelines {
    display: none;
I was just about to do that hack myself :slight_smile:. Haven’t seen another way of doing it..
It does, and I think this is the way to go, as there are no more straightforward solution to at this time to my knowledge :slight_smile:
So, I think the answer to:
is “Yes”. :slight_smile:
