Separando FAQ e Diretrizes da Comunidade - preciso de ajuda!
Hi there! I’m working on setting up stronger community guidelines for our forum. Right now the both the /guidelines and /faq urls on the forum link to a page called “FAQ”.
The welcome message from Discobot which contains the link to the current community guidelines also directs to this FAQ page.
And the hamburger menu on the right side has a link to “FAQ” as well - again, the same page.
Now I’d love to replace this FAQ with our Community Guidelines and eventually create another page for the FAQ. Has anyone had this issue before? How did you deal with the url issue?
Search for FAQ in the admin. There’s a setting that allows you to set that link to any url you want
You can also edit the FAQ to your linking
5 curtidas
Note that if you set faq_url, the existing FAQ document turns into the community guidelines document.
4 curtidas
