Composer Popup Messages Guide
The discussion revolves around the accuracy and currency of the ‘Composer Popup Messages Guide’ for Discourse administrators. one1 notes a terminology inconsistency between the page title and content, while Moin and one1 highlight that several site settings and text keys are outdated or invalid following recent changes. ToddZ provides specific examples of removed settings like max_similar_results and deleted composer tips, urging an update to the documentation. In response, sam confirms that the guide has been updated to remove obsolete information. Additionally, pHneutre suggests linking to resources on displaying custom messages and pre-filled composer templates.
:bookmark: This guide explains the various composer messages that can appear, their relevant site settings, and how to disable them.
:person_raising_hand: Required user level: Administrator
In Discourse, certain popup messages appear when users are composing posts.
These messages, known as composer education messages, serve educational and moderation purposes, guiding users on best practices and reminding them of community guidelines.
In this guide, we’ll explain the details and context about each composer message, and how to turn off these popups if desired.
Detailed composer messages and associated site settings
Below is a comprehensive list of composer education messages, their associated text key, their related site settings, the conditions under which they appear, and the default message they display:
New user education messages
Educate new topic
This message appears the first time a user starts a new topic.
  • Text key: education.new-topic
  • Site setting: educate until posts
    • Determines how many of a user’s initial posts will trigger the display of the new user education panel in the composer.
  • Message:
Educate new reply
This message appears the first time a user replies to a topic.
  • Text key: education.new-reply
  • Message:
Limited replies for new users
This message appears when a new user reaches their reply limit for a single topic.
  • Text key: education.too_many_replies
  • Site setting: newuser max replies per topic
    • Sets the maximum number of replies a new user can make in a single topic until someone else replies to them.
  • Message:
Dominating the topic
This message encourages users to allow others to participate when they post too frequently in a topic.
  • Text key: education.dominating_topic
  • Site setting: dominating topic minimum percent
    • Indicates the percentage of posts a user must have in a topic before they are reminded about overly dominating the discussion.
  • Message:
Get a room prompt
This message suggests switching to personal messages if a user is having a prolonged back-and-forth with another user.
  • Text key: education.get_a_room
  • Site setting: get a room threshold
    • Defines the number of posts a user can make to the same person in a topic before being warned to “get a room” and consider other participants.
  • Message:
Don’t feed the trolls
This message warns users about replying to flagged posts which might encourage negative behavior.
  • Text key: education.dont_feed_the_trolls
  • Site setting: don't feed the trolls threshold
    • Specifies the number of flags from other users that a post must receive before triggering a warning message to the user.
  • Message:
Similar topics
This message appears when a user attempts to create a topic similar to another existing topic.
  • Text key: js.composer.similar_topics
  • Site settings:
    • min_title_similar_length
      • This setting determines the minimum length a title must have before it is checked for similar topics. If the title length is below this threshold, the check for similar topics will not occur.
    • minimum_topics_similar
      • This setting defines the minimum number of topics that must exist before similar topics are suggested when composing new topics.
  • Message:
Solved topic education message
This message appears when a user attempts to reply to a topic that has already been marked as solved. This message is part of the discourse-solved plugin.
  • Text key: education.topic_is_solved
  • Site setting:
    • disable_solved_education_message
      • When enabled, this disables the education message that appears when users try to reply to solved topics.
  • Message:
Disabling composer popups
Using CSS
Here’s how you can disable all composer education messages by using CSS:
  1. Open your site’s admin panel.
  2. Navigate to the “Appearance → Themes” section of your site. (/admin/customize/themes)
  3. Add the following CSS code to your theme:
    /* Hide all composer education messages */
    .composer-popup {
        display: none;
  4. Save the changes.
This code will hide all composer education messages across your site.
Adjusting site settings
If you prefer to only disable specific messages, you can adjust the relevant site settings instead.
Alternately, you can edit the contents of the popup message from your .../admin/customize/site_texts page.
Last checked by @MarkDoerr 2026-09-11T22:16:14Z
In the text it calls them “composer education messages” but in the title of this page it calls them “composer popup messages.” Not sure if it matters.
It looks like the education_posts_text is no longer valid?
The text was changed in May. The current version is
Thanks for contributing to %{site_name}!
Before you post, please select a category or tag to group this topic with related discussions so that it's easy for others to find it.
For more tips and advice on participating in our community, [check out our community guidelines](%{base_path}/guidelines).
So the only available keys are site_name and base_path
The topic could benefit from an update. There have been several changes regarding education messages in recent months. Some no longer exist.
Thanks! Is there someone we should @?
I don’t think @mentioning a team member is a good idea
thanks for the note Moin, we’ll get someone to update this topic.
As of the Dec 1 edit to this topic there are still some issues. Ex:
Under Similar topics:
  • max_similar_results was removed in May
  • the setting min_topic_count_similar_results seems confabulated and should be minimum_topics_similar
Composer tips removed in June:
  • upload avatar
  • sequential replies
  • reviving old topic
(I haven’t reviewed every section – these are just things that have recently come up elsewhere.)
I updated the doc and removed them :hugs:
Could this topic also link to how to display custom messages to the user and pre-filled composer (template)? That’s what I was looking for. :slight_smile:
