Reindirizzamento permalink /conduct a /guidelines che fallisce internamente
Continuing the discussion from Permalink normalizations don't work for internal links:
We prefer the term “conduct” as in Code of Conduct, and we added a permalink /conduct to go to /guidelines. That works from external links, but not internally. There’s no way to allow this?
Thing is: We call the page “Code of Conduct” and we have a different topic of “extra healthy discussion guidelines” for the good-advice that isn’t the CoC… and so, telling everyone to remember to use /guidelines when they want to link to the CoC is confusing. We’d like to be able to tell everyone that they can always link to /conduct. But if that fails internally, it’s not so usable…
I would wish that we could rename /guidelines URL or rather (to avoid breaking anything) have permalinks work internally.
As discussed on the linked topic, permalinks don’t work internally.
If you really want to you could create a plugin that would add that link.
We internally added a synonym here for
/rules
so I think it’s maybe OK to add another synonym for
/conduct
if you think that’s OK as well @neil?
Ok sounds fine to me.
https://github.com/discourse/discourse/commit/6774b64aef546bffdd32f4485c12e059bccd2348
