Errore di connessione dopo il ridimensionamento del Droplet DO
Hi guys, I resized my DigitalOcean droplet today, and after that process was completed I haven’t been able to access my Discourse forum (I’m getting ERR_CONNECTION_REFUSED).
It looks like something other than Discourse is using port 80… This is what I get when trying to restart the app (I have also rebuilt it, and restarted the DO droplet itself):
root@community:/var/discourse# ./launcher restart app
+ /usr/bin/docker stop -t 10 app
app
starting up existing container
+ /usr/bin/docker start app
Error response from daemon: driver failed programming external connectivity on endpoint app (aa51af7b44babc340fc1101b508092e99c65b05cdda7c39ce8337d4f56f0bde7): Error starting userland proxy: listen tcp 0.0.0.0:80: listen: address already in use
Error: failed to start containers: app
Any ideas how I can continue debugging or getting this fixed? Discourse was running perfectly fine until I resized the droplet…
Run netstat -plnt to find what is listening on port 80.
You probably have Nginx or Apache installed on the server. You should remove them and
cd /var/discourse
./discourse-setup
to reconfigure Discourse for the amount of RAM you have.
Yup, looks like apache was listening.
root@community:~# netstat -plnt
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1318/sshd
tcp6       0      0 :::80                   :::*                    LISTEN      1478/apache2
tcp6       0      0 :::22                   :::*                    LISTEN      1318/sshd
For future reference (or to help other noobs), I ran sudo apache2ctl stop, then ./discourse-setup like @pfaffman suggested to reconfigure for the new amount of RAM. At the end of that process discourse was rebuilt and my site is back up!
I’m not sure if this was necessary, but finally I ran sudo systemctl disable apache2 to make sure apache does not run when my droplet is restarted in the future. (Source)
Thanks a lot guys!
Yes, that was a very good idea.
Right. Perhaps a better idea would be
apt purge apache2
but that’s assuming that your apache server package is named just that. You can see what all apache stuff is installed like
sudo dpkg -l |grep apach
You really need to un-install the main server part. The other stuff won’t hurt you and can get removed with
apt -y autoremove
