You can now customize Invite email message when inviting user to forum, topic or message.
The resulting invite email will look like:
This worries me. If Discourse is checking for the link before sending, why not alert the user that they must include the link, instead of silently ignoring the message?
Good point! Added on my list. ![]()
Agreed – or just prevent the button from being pressed, if that key string is not present in the text? That might be simpler.
My concern here is that people don’t understand templates.
Instead why not simply give them a dedicated spot in the invite for a “custom message” and then allow them to add it in here.
It just feels a little bit too flexible and “technical” this way to me.
Sure, I support that – @techapj can you change it so
When “custom message” is expanded, a textbox with some suggested copy is shown. No template, just plain text:
Hey, I thought you might enjoy this topic!
If user enters text, that is inserted into the template on their behalf in the {user_custom_message} template field or what have you.
Note that this is also safer – with the current design, the sender could totally subvert the message, maybe even use it for spamming.
Okay, done via:
Updated the OP to reflect the same.
hmm, this message could be better:
FEATURE: user-friendly custom message · discourse/discourse@40e9e1b · GitHub
This invitation is from a trusted user, so you won’t need to log in.
How about something like this:
This invitation is from a trusted user, so an account will be created for you automatically.
You’ll get another email with instructions on how to sign in next time.
Sure, I think that suffices; no need to add another extra line.
