Daily digest is not working
סיכום מבוסס בינה מלאכותית
The discussion revolves around issues with the daily digest email feature not functioning as expected. James_Harakaly reports that the digest isn’t sending daily emails, despite adjusting email settings, and suspects the plugin may be the cause. ToddZ clarifies that the built-in digest defaults to weekly and asks if the user has changed the setting to daily, referencing a screenshot. James_Harakaly confirms the setting is already on daily and explains that using the daily digest plugin resolved the issue. ToddZ further explains the distinction between the built-in digest and the daily summary plugin, noting that the latter is an unofficial plugin revived to restore the feature of sending daily emails, and that the built-in digest only sends emails to inactive users, not every new post. The conversation highlights confusion between the terms ‘digest’ and ‘daily summary’ and suggests the plugin is needed for the desired functionality.
is anyone else having issues with the digest not sending out daily?
I’ve tried updating every single setting for emails for them to be allowed and to work, but the guy just still wasn’t being sent out. So either leave the notification email list on and it sends out an email for every single post that happens on the site or I get nothing.
I don’t want to users to get emails for everything on the site, I just want them to get a daily summary email.
Any thoughts or feedback would appreciated
So I tried out the daily summary plug-in and I thought it worked because it sent it out once, but then it hasn’t sent out in two days.
I don’t know about that plugin, but re. the standard digest, there are a couple of settings your screenshot didn’t show:
The factory setting is weekly – have you changed this to daily?:
Screenshot 2025-11-06 122759
If this isn’t set and you only have new posts from TL0 users, nothing would go out. The factory setting is ‘off’:
Hi Todd,
Truly appreciate your help with this. Have a great weekend.
I do have it set to daily and I did have that check box selected.
Since it wasn’t working by default, I decided to try the daily digest plug-in. Once I actually set that up properly, I was able to get the digestive send correctly.
I installed the daily summary plug-in and I left these two settings blank because I thought they would be default to everybody and everything. But once I actually set them to everyone and I just selected all of my categories and categories it seems to be working.
-James
Hi James – there’s often some confusion around here because the terms Digest and Summary are sometimes used for the same thing. In reading what you’ve been up to, it can be a bit hard to tell which feature you’re talking about.
Generally, the “Digest” refers to the built-in feature that sends a selection of recent topics to users who haven’t visited in a while, based on timeframe settings (default 1 week.)
The “Daily Summary” was an old feature that apparently sent every new thing to users on a daily basis. It was revived with an unofficial plugin, Restore Mailing List Mode Daily Summary, which was later forked with additional functionality to Discourse mail daily summary plugin.
Skimming the topics for these unofficial plugins, it sounds like they can overlap in ways with the built-in Digest that can be hard to troubleshoot. And as the author of the forked plugin notes here, it’s basically unsupported at this point.
In your place, I’d probably remove whichever unofficial plugin you’ve installed and get to know how the built-in Digest works. It’s quite flexible and serves most purposes well.
Once you have a handle on that, if it’s not doing what you need, you could try a Daily Summary Plugin and see what happens. Then you’d be better able to pinpoint any issues, and perhaps commision someone to fix them.
