Moin
13 ביולי, 2026, 9:53pm
1
A while ago the notification prompt was added to the topic voting plugin
Notification prompts after voting
After a member votes for an idea, Discourse will ask members if they want to get notified about new posts in this topic. When selected, this will update the notification level for the topic to Watching so they can stay on top of new activity in this topic. This change makes it easy for members to opt-in to updates about ideas they care about.
And you also
I noticed that the notification feature doesn’t seem to work when topic voting enable vote limits is disabled.
I have the impression the menu is suppressed if there is no need to show the remaining number of votes, which results in the notification feature being blocked too:
Votes limited:
Unlimited votes:
2 לייקים
zogstrip
(Régis HANOL)
15 ביולי, 2026, 10:41am
3
Thanks for the report @Moin It’ll be fixed by
main ← fix-topic-voting-notification-prompt-vote-limits
merged 12:54PM - 15 Jul 26 UTC
When topic voting vote limits are disabled, the "Notify me about new posts"
prom… pt shown after voting never appeared. That prompt is part of the menu the
vote button opens, but the menu was only rendered when vote limits were
enabled — with limits off the button had no menu at all, so both the
notification prompt and the remove-vote action were unreachable.
The fix renders the menu for any signed-in user rather than gating it on vote
limits. The remaining-votes rows stay tied to limits being enabled, while
remove-vote and watch-topic show whenever the user has voted. Removing a vote
with limits disabled now goes through the menu, matching the behavior when
limits are enabled.
Reported at https://meta.discourse.org/t/disabling-vote-limits-seems-to-break-notification-prompt-in-topic-voting/407512
The second commit is follow-up housekeeping on the plugin, kept separate from
the fix: removing dead code and duplication in the vote components and
initializers, counting a user's votes with `COUNT` instead of loading every
row on each current-user serialization, and deleting orphaned i18n keys and a
route-map filename left over from the plugin's former name.
### Testing
- Added a system spec covering the notification prompt appearing after voting
with vote limits disabled.
- Existing topic-voting system and JS specs pass; the model spec still covers
the trust-level-0 lock via `reached_voting_limit?`.
2 לייקים
