Like the other bug I’ll probably have a shot at fixing this after I submit my PR, although I wouldn’t say I’m particularly confident at my ability to fix it. If no-one hears from me for a few days please send a search party.
Errr this is not a bug. This is expected behavior. There is one and exactly one new topic draft available to you at any given time. (compare with literally infinite reply drafts, one per every topic in the system, potentially)
You can get back to it by triggering a new topic creation.
New topic creation is how you get back to your topic draft.
The trouble is, “continuing the discussion from” drafts (drafts with draftKey = "reply_as_new_topic") don’t behave as other drafts do, nor as (I think) it should.
Because a picture tells a thousand words, and a thousand words still isn’t enough, this should show what I mean:
Hi Leo! Personally I am with @codinghorror on this issue. It can behave the same way as all new messages. I do think someday someone should create a drafts folder and system for managing and limiting drafts (it’s clunky to not be able to keep a few drafts going whether new or reply) but it’s not a pressing issue.
There is much draft consistency now, if you reply as new topic it uses the draft key for the topic you are on, so you can easily return to it either from “drafts” or by visiting the topic.
