Disappearing posts in 2.1.0.beta2
סיכום מבוסס בינה מלאכותית
The discussion revolves around an issue with disappearing posts on discourse.suttacentral.net after updating to Discourse 2.1.0.beta2. Vimala_Ayya reported the issue and provided a screenshot. sam suggested updating again, but Vimala_Ayya mentioned that the system says it’s up to date.
pfaffman suggested checking the admin upgrade page, while sam recommended trying safe mode. Vimala_Ayya attempted both suggestions and found that the issue persists, but only when the theme is disabled in safe mode. This led to the conclusion that the problem might be related to non-official plugins.
We recently updated discourse.suttacentral.net to 2.1.0.beta2.
But now if you scroll through posts, they sometimes just disappear, leaving a blank space:
Please update again asap
Says we’re up to date and won’t let me update again.
Did you try http://discourse.suttacentral.net/admin/upgrade ?
Can you try in safe mode? Using Safe Mode to troubleshoot issues with themes and plugins
Thanks. I’ve done that several times (new upgrades appear very regularly) but the problem persists.
I could recreate the problem in safe mode only when I just disabled the theme and nothing else. With any other combination of disable-options the problem did not show. Now I take it that “disable all plugins” also includes the non-official plugins so the problem should be found somewhere in there.
