Discobot image lesson may not be working in some circumstances
סיכום מבוסס בינה מלאכותית
A bug has been reported in the Discobot image lesson, where it incorrectly responds with “Looks like you didn’t upload an image” when a user replies with an image but doesn’t like the original post. anon80167013 initially reported the issue, which was later reproducible by jomaxro. The error occurs when a user drags and drops the image from Discobot’s post instead of uploading from their desktop. jomaxro was able to reproduce the issue again, and codinghorror clarified that dragging and dropping from the post is not a supported behavior.
Further investigation revealed that the issue is due to the image being converted into a onebox, which is not counted as an image by the post analyzer. tgxworld suggested a solution to make the rules more lax for Discobot, considering any image tag in the cooked post as a valid image. The issue has been fixed in a commit to the Discourse GitHub repository, thanks to the reporting and debugging efforts of anon80167013 and jomaxro.
The image lesson is the first lesson that asks you to do two things:
  • like the image Discobot sends you
  • reply with an image
If you just reply with an image, Discobot says:
even though the image is fine, and it’s just that you need to like the message. Probably it should either not require you to do two things in response to one message, or be clearer that you have to like it, or just actually tell you that you need to like it if you reply without having done so.
(Someone else already reported this here, but apparently it’s not reproducible – initially, I dragged the image Discobot sends you into the reply box; once I failed it once, I copied the link Discobot sends you, and both times I just got “Looks like you didn’t upload an image”, not anything about needing to like the message.)
4 לייקים
Can you repro this @jomaxro?
לייק 1
Yep, can repro. If you upload an image but don’t like the post, you get the “no image found” error, instead of the expected “why didn’t you like my post?”
5 לייקים
Hmm how did this regress @tgxworld, maybe take a look when you are fully back
@jomaxro Can you provide me with the exact steps that you took?
I tested on both try and meta which gave me the correct behavior.
4 לייקים
Definitely no repro on try @jomaxro …
.. if you are somehow getting this to happen, it is subtle. We are gonna need literal click by click and touch by touch instructions.
לייק 1
Interesting, my testing was on try too, so :man_shrugging:? I’ll see if I can repro it again, and note the steps more specifically.
Repro’d it again. What I did was dragged and dropped the picture of the unicorn from discobot’s post, which caused the “you didn’t upload a picture” error.
I can confirm that uploading an image from local (I tested via drag and drop) works as expected, and I see the “did you forget to :heart: my post” reply.
2 לייקים
This .. this .. has never been a supported behavior..
You haven’t actually added an image in that case. When we say “drag and drop” we mean drag from the desktop and drop.
Except the error text that you get implies oneboxing will work. (emphasis mine)
True, does that one not work? If so that’s a bigger bug.
It didn’t work after I failed with the unicorn picture. I can try again by pasting that first, before I drag and drop the unicorn. One sec…
Can confirm that pasting the link explicitly mentioned by discobot fails too.
לייק 1
OK so looks like that’s the regression @tgxworld – it should detect that as an image.
2 לייקים
Ahh I see what the problem is here. When a link to an image is given, it gets converted into a onebox. Any images that are present within a onebox are not counted as an image as far as our post analyzer is concerned. I guess we can be more lax with the rules for discobot such that any image tag in the cooked post is considered to be a valid image?
4 לייקים
Sounds good to me, let’s make it so!
Fixed in
https://github.com/discourse/discourse/commit/6fde58ff90bcf1f7274883050af8a3206bf9f7dd
Thank you for reporting @anon80167013 and thanks to @jomaxro for figuring out the reproduction steps :slight_smile:
6 לייקים
