My team has a discourse forum running on the Discourse hosting service. We currently subscribe to the ābusinessā plan, so my question is: can we use that āDiscourse AI Topic Summaryā plugin? I am not sure if it is included in our current plan or if we would have to go up to the āenterpriseā.
Sometimes the AI gets too creative despite the direction we are giving it here , so you can restrict it to the set of existing ones.
you can quickly create a non-admin user for this purpose from the rails console by using:
rake admin:create (donāt give this user admin priviliges!)
(This is a bit of a hacky workaround because the current Discourse āinternal APIā for tagging currently does not allow you to specify āno new tagsā, so the only way of easily preventing this at present is by creating them as a user that does not have that privilege (ie trust level less that min_trust_to_create_tag)
Thanks for the update. Iāll check the changes out.
The new function capability is something we are looking at too. The idea of being able to get consistent structured data back from the api call is very exciting! And who could complain about longer context
The user in this plugin is only used to restrict tag choice ā¦ if you re-use the same AIBot user it will likely have rights to create new tags because it will probably have high privilege in order to post everywhere. Iāve not tried it but perhaps you can keep AIBot at a low TL.
If you donāt mind it creating new tags then thatās ok, but results are usually better if you prevent it from doing so.
sudo ./launcher rebuild appļ¼You are specifying the gem tokenizers in /var/www/discourse/plugins/discourse-ai/plugin.rb, however it does not exist!
discourse-topic-voting is already at latest compatible version
discourse-translator is already at latest compatible version
discourse-user-notes is already at latest compatible version
discourse-whos-online is already at latest compatible version
discourse-yearly-review is already at latest compatible version
docker_manager is already at latest compatible version
I, [2023-09-23T12:57:22.787693 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
ERROR: While executing gem ... (Gem::RemoteFetcher::FetchError)
too many connection resets (Gem::RemoteFetcher::FetchError)
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/request.rb:250:in `rescue in perform_request'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/request.rb:194:in `perform_request'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/request.rb:155:in `fetch'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/remote_fetcher.rb:310:in `request'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/remote_fetcher.rb:210:in `fetch_http'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/remote_fetcher.rb:249:in `fetch_path'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/remote_fetcher.rb:286:in `cache_update_path'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/remote_fetcher.rb:157:in `rescue in download'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/remote_fetcher.rb:142:in `download'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/source.rb:208:in `download'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/resolver/specification.rb:113:in `download'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/resolver/specification.rb:99:in `install'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/request_set.rb:280:in `block in install_into'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/request_set.rb:272:in `each'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/request_set.rb:272:in `install_into'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/request_set.rb:148:in `install'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/commands/install_command.rb:215:in `install_gem'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/commands/install_command.rb:231:in `block in install_gems'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/commands/install_command.rb:224:in `each'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/commands/install_command.rb:224:in `install_gems'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/commands/install_command.rb:170:in `execute'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/command.rb:328:in `invoke_with_build_args'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/command_manager.rb:253:in `invoke_command'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/command_manager.rb:193:in `process_args'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/command_manager.rb:151:in `run'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/gem_runner.rb:52:in `run'
/usr/local/bin/gem:12:in `<main>'
I, [2023-09-23T13:23:20.135088 #1] INFO -- : gem install tokenizers -v 0.3.3 -i /var/www/discourse/plugins/discourse-ai/gems/3.2.2 --no-document --ignore-dependencies --no-user-install
Looked for:
- /var/www/discourse/plugins/discourse-ai/gems/3.2.2/specifications/tokenizers-0.3.3.gemspec
- /var/www/discourse/plugins/discourse-ai/gems/3.2.2/specifications/tokenizers-0.3.3-x86_64-linux.gemspec
I, [2023-09-23T13:23:20.135292 #1] INFO -- : Terminating async processes
I, [2023-09-23T13:23:20.135305 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
I, [2023-09-23T13:23:20.135317 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 110
110:signal-handler (1695475400) Received SIGTERM scheduling shutdown...
2023-09-23 13:23:20.135 UTC [41] LOG: received fast shutdown request
2023-09-23 13:23:20.152 UTC [41] LOG: aborting any active transactions
2023-09-23 13:23:20.154 UTC [41] LOG: background worker "logical replication launcher" (PID 50) exited with exit code 1
2023-09-23 13:23:20.155 UTC [45] LOG: shutting down
2023-09-23 13:23:20.198 UTC [41] LOG: database system is shut down
110:M 23 Sep 2023 13:23:20.223 # User requested shutdown...
110:M 23 Sep 2023 13:23:20.223 * Saving the final RDB snapshot before exiting.
110:M 23 Sep 2023 13:23:20.286 * DB saved on disk
110:M 23 Sep 2023 13:23:20.286 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1163 exit 255>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
bootstrap failed with exit code 255
d793fa4559a2f3b78d3bc76c74387dbbaf131de653790d71915713b4a6529f05
