Discourse Android App keeps on crashing
The Android app keeps on crashing. It is annoying as it tends to break my writing momentum. The good thing is that what I have been typing is usually saved.
Can you list phone model, OS version, etc?
Anyone else using the Android app seeing this?
Model: Gionee P5 Mini
OS: Android 5.1
Memory: 4 GB internal + 16 GB SD Card
Ram: 1 GB
I do have the stack trace of your crash.
com.discourse_issue_5_crash_5A20FDC301F500012E4FFBB515CA2704_4245efdfd66511e7a5d056847afe9799_0_v2.txt (27.5 KB)
We have an update which should be available next week, I suggest wait to see if this update is fixing things for you, otherwise I will investigate.
Alright then. I’ll wait. Thanks.
Hi. The update is not yet available on playstore. The app is still crashing, and it is a bit frustrating to be returned to the app landing page every few minutes.
I pushed a beta build to our team today, maybe I can send you the apk
That’ll be great. Thanks.
I released the android app on the store, let me know how it goes for you
I’ve updated it. I’ll let you know how it goes. Thanks.
This topic was automatically closed after 3 days. New replies are no longer allowed.
