Discourse installation timed out
Hi, I want to install discourse. My logs look like this:
redis.1  | 410:M 31 Aug 2021 07:34:15.596 # Server initialized
redis.1  | 410:M 31 Aug 2021 07:34:15.871 * DB loaded from append only file: 0.275 seconds
redis.1  | 410:M 31 Aug 2021 07:34:15.871 * Ready to accept connections
web.1    | [405] Puma starting in cluster mode...
web.1    | [405] * Version 5.0.4 (ruby 2.7.2-p137), codename: Spoony Bard
web.1    | [405] * Min threads: 2, max threads: 4
web.1    | [405] * Environment: production
web.1    | [405] * Process workers: 1
web.1    | [405] * Preloading application
worker.1 | 2021-08-31T07:34:19.878Z pid=406 tid=diy INFO: Booting Sidekiq 6.1.2 with redis options {:host=>"localhost", :port=>6379, :namespace=>"sidekiq"}
logs.1   | Creating scope :open. Overwriting existing method Poll.open.
web.1    | [405] * Listening on unix:///var/www/discourse/tmp/sockets/nginx.http.sock
web.1    | [405] ! WARNING: Detected 3 Thread(s) started in app boot:
web.1    | [405] ! #<Thread:0x000055d018a50468 /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:334 sleep> - /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.0.3.3/lib/active_record/connection_adapters/abstract/connection_pool.rb:337:in `sleep'
web.1    | [405] ! #<Thread:0x000055d01a463fa8 /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.4/lib/message_bus.rb:712 sleep> - /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/redis-4.2.5/lib/redis/connection/ruby.rb:55:in `wait_readable'
web.1    | [405] ! #<Thread:0x000055d01a463c60 /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.4/lib/message_bus/timer_thread.rb:38 sleep> - /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/message_bus-3.3.4/lib/message_bus/timer_thread.rb:130:in `sleep'
web.1    | [405] Use Ctrl-C to stop
It looks like the installation completed successfully but then this WARNING: Detected 3 Thread(s) started in app boot appears. From now on nothing happens and the website never goes online: https://discourse-web-5c2g.onrender.com/
follow this install guide
Render installs are custom and not supported by us. Either follow the official install guide or contact Render support about the problem in their product.
Thanks for your answer..
