Can anyone think of a way i could automatically grant a custom badge for making a post that renders an equation using the discourse-math plugin?
No idea where to start on this
The discussion revolves around automatically granting a custom badge for making a post that renders an equation using the Discourse-math plugin. agf1997 is looking for a simple way to encourage users to use the math typesetting feature. neounix suggests modifying or extending the math plugin to update a custom field in the DB when a forum member uses the plugin, which could then be used to issue badges.
However, Falco provides an alternative solution using a badge SQL query that triggers on posts containing math equations, without requiring plugin modifications. The query is:
SELECT user_id, MIN(id) AS post_id, current_timestamp AS granted_at
FROM badge_posts
WHERE cooked LIKE '%<span class="math">%' AND (:backfill OR id IN (:post_ids) )
GROUP BY user_id
neounix asks for a concise reference for the Discourse Ruby symbols that can be used in a badge query, and agf1997 reports that the provided query does not work on previous posts, seeking further assistance.
Hi @agf1997
Agree the Discourse math plugin is well done and a great addition for a site.
One approach would be to pay a Discourse plugin developer to modify the math plugin for you to update a custom field in the DB when a forum member uses the plugin.
Then, you could create an easy DB query (in the badge admin area) to issue badges.
Hope this helps.
It’s certainly not a mission critical feature. I was just looking for a simple way to highlight people using the math typesetting feature to encourage others to use it also.
Hi @agf1997
You will need plugin code for that, as I mentioned.
This would indicate you have two choices:
What ever direction you decide to go in you need to modify or extend the math plugin to update a custom field in the DB when a forum member uses the plugin.
Hope this helps.
Yes, you can have badges for successful Math posts without having to modify the plugin.
First you will need to enable Badge SQL can no longer be edited by default on your site.
After that create a new badge that triggers on the following query:
FROM badge_posts
GROUP BY user_id
Hey @Falco
That is a really nice badge query.
Question:
Do you have a list of all the Discourse :symbols that can be used in a badge query to help trigger?
The reason I ask is that I see you used :backfill and :post_id and when I look at this link, I see other Ruby :symbols used:
Is there a concise reference for the Discourse Ruby symbols that can be used in a badge query?
I did find this, related to badge triggers (after your post above), which was very helpful:
In that Discourse article, mentioned are these trigger helpers:
Are these three “all of them”?
Thanks so much for your help!
@Falco Awesome! Quick question .. should this work on previous posts? When I click “Preview granted badges” I get “No badges to be assigned.”
Clicking “Preview with query plan” gives me
GroupAggregate (cost=2021.68..2021.70 rows=1 width=16)
Group Key: p.user_id
-> Sort (cost=2021.68..2021.68 rows=1 width=8)
Sort Key: p.user_id
-> Nested Loop (cost=0.28..2021.67 rows=1 width=8)
Join Filter: (t.category_id = c.id)
-> Nested Loop (cost=0.28..2017.97 rows=1 width=12)
-> Seq Scan on posts p (cost=0.00..2009.66 rows=1 width=12)
Filter: ((deleted_at IS NULL) AND (cooked ~~ '%<span class="math">%'::text) AND (post_type = ANY ('{1,2,3}'::integer[])))
-> Index Scan using topics_pkey on topics t (cost=0.28..8.30 rows=1 width=8)
Index Cond: (id = p.topic_id)
Filter: ((deleted_at IS NULL) AND visible)
-> Seq Scan on categories c (cost=0.00..3.35 rows=28 width=4)
Filter: (allow_badges AND (NOT read_restricted))
