דיסקוס לא נפתח
When I am going to my server IP ( 139.59.88.71)
but its not showing discourse
but if I run netstat -tulpn
Then it shows port 80 is open!
Discourse isn’t designed to be used on an IP address. You’ll need to configure an FQDN.
the ip is linked to the domain too!
Welcome! Did you use Discourse official Standard Installation. If not, we can’t help, as there is little way to guess what might be wrong.
You need both ports 80 and 443 open to the world. If you’re using cloudflare you should make it dns only.
As mentioned, you can’t use a bare ip number. Misconfigured dns is a common issue. It often helps if your can share your hostname.
