Discourse Response Bot
Hi,
This is a plugin that automatically replies new posts with a wiki post for collaborative answers.
You can clone the repo here: GitHub - bolariin/discourse-response-bot: A discourse bot that automatically replies newly created topics with a wiki post
You can:
  • change the default text in settings
  • enable or disable the plugin in select categories
Feel free to try the plugin, report issues, ask questions or suggest improvements or fixes.
It seems very cool!
Can responseBot username be changed for an active user of the forum? That’s feeel more comfortable for new posters.
@satonotdead
Currently the username is hardcoded.
you can change it, but would need to make a copy of the repo and then load that repo
EDIT
works like a charm
Thanks, I will try it :slight_smile:
What about using default bot (we bot has name and avatar) or changing the avatar in Response Bot?
as an admin, you can change the bot’s avatar. Let me change it to system and see what it does… change the bot id and now its using discobot :slight_smile:
