eazoppe
(Eazoppe)
October 11, 2021, 7:41pm
1
Okay so I am trying to setup my own Discourse forum on DigitalOcean using the one click system but when I get to which domain I should set it up on, I just keep getting the error of Port 443 of computer does not appear to be accessible.
I am using CloudFlare for my DNS and I have searched and tried everything and have kept getting the same error over and over again. Would someone please assist me?
IAmGav
(Gavin Perch)
October 11, 2021, 7:43pm
your domain is not pointing to DO.
That is why you getting that error
eazoppe
(Eazoppe)
October 11, 2021, 7:44pm
3
It is though.
I set my Domain to go to my DigitalOcean public IP.
IAmGav
(Gavin Perch)
4
what is the url you going to use ?
eazoppe
(Eazoppe)
October 11, 2021, 7:45pm
5
IAmGav
(Gavin Perch)
October 11, 2021, 7:49pm
6
check you A records on cloudflare.
its not allowing the traffic to DO
eazoppe
(Eazoppe)
October 11, 2021, 7:52pm
7
It’s not blocking anything. So it should be allowing the traffic to DO.
Steven
October 11, 2021, 8:01pm
8
The domain points to cloudflare ips. Which is signs that the ns servers are well configured.
But on cloudflare, you need to add an A record on the subdomain : forum(.rankerprobot.com), with the ip of the digitalocean droplet as a target.
eazoppe
(Eazoppe)
October 11, 2021, 8:04pm
9
I did do that and I am receiving the same error that I was getting before.
IAmGav
(Gavin Perch)
October 11, 2021, 8:07pm
10
Proxy Status should be set to DNS only.
eazoppe
(Eazoppe)
October 11, 2021, 8:11pm
11
There we go, it worked. Thank you for your help.
system
(system)
Closed
November 10, 2021, 8:13pm
13
