Discourse Sidebar Blocks
The discussion revolves around the Discourse Sidebar Blocks plugin, which is now deprecated in favor of the Right Sidebar Blocks theme component. The plugin displays customizable blocks—such as category posts, latest replies, and custom HTML—in a sidebar on discovery pages (e.g., latest, new, unread), but not on individual topic pages. It supports desktop only and allows configuration via plugin settings, including enabling the sidebar, ordering blocks, and adding custom HTML. The plugin is compatible with Discourse 1.8.0.beta1 and has seen updates like configurable category post counts and live updates for replies. Users have reported issues, including conflicts with other plugins (e.g., Topic List Previews, Dynamic Sidebar), layout problems on mobile, and CSS styling for hiding or adjusting the sidebar. Some contributors have proposed improvements, such as adding a leaderboard block and enhancing the two-column layout. The plugin’s repository is available at https://github.com/pmusaraj/discourse-sidebar-blocks.
:warning: This plugin is now deprecated. Please use the Right Sidebar Blocks theme component instead.
This plugin shows a list of blocks as a sidebar on all discovery list pages (latest, new, unread, categories but not on the single topic page). The available blocks at this point (Oct. 12 2016) are the following:
  • multiple category posts (6 items max per category)
  • latest replies (5 items)
  • a custom html block
Blocks can be ordered in the plugin settings. Speaking of which, there are these settings under Admin > Settings > Plugins:
  • sidebar enable enables the display of the sidebar
  • sidebar block order is a list of “tags” that can include category slugs, latest_replies for the replies block and custom_html for the custom HTML content
  • sidebar custom content where you can enter arbitrary HTML content to show on the sidebar
The plugins works on desktop only, and there are no plans to add it to the mobile view. You can see a real like site with the plugin at peshkupauje.com (an Albanian community blog/forum) where it’s working quite well alongside the Topic List Previews and the Links Category plugins.
Upcoming features
I would like to add the following features to the plugin:
  • auto-refresh content in sidebar blocks, like in main column
  • performance improvements
If anybody has any ideas on how to add the auto-refresh feature, please let me know.
Repository: GitHub - pmusaraj/discourse-sidebar-blocks · GitHub
Screenshots:
Cool :slight_smile:
You need to add a (or use an existing) messageBus publication and subscription. E.g.
Publication: discourse-ratings/plugin.rb at main · paviliondev/discourse-ratings · GitHub
Subscription: https://github.com/angusmcleod/discourse-ratings/blob/master/assets/javascripts/discourse/pre-initializers/ratings-edits.js.es6#L36
I’ve been working on a ‘three column’ version of Discourse for my own project for a little while. I’m not quite ready to share it with the world yet, but considering you’re working on something similar, I’ll let you know that I plan to release in plugin form in the nearish future.
The relevant part here is contextual ever-present columns. The columns are always there, including in topics (not in the admin panel though). All navigation is moved to a component in one of the columns. The components ‘know’ where they are at all times because I’ve added various route properties to the application controller that get refreshed each time there are any route changes.
This is slightly different from what you’re doing here, however it may have some cross-over.
Thanks Angus, I will look into messageBus!
This three-column layout looks interesting, would be happy to test it out once you have it closer to release (or whenever you will be looking for feedback).
sidebar blocks are not working in the latest update. is that the case for you as well?
p.s.: two suggestions regarding Angus design @angus :
  • Latest replies of topics can be shown in the excerpt area rather than topic excerpt, so you need less click to get updated.
  • the big search box can work for creating topic as well. less click to start a discussion in this social-style homepage.
I just tested it on a local site with current master, and it works for me. Do you have other plugins on your site that may break?
thanks for the confirmation.
cakeday, header search, and of course topic list preview; other than default plugins.
maybe it’s because of the crash we experienced recently, I’ll rebuild the app to see if it becomes ok.
after update to latest discourse and latest sidebar, everything has vanished :confused:
I’m not sure if sidebar is working on the latest at all.
And if you remove the plugin and rebuild app, Discourse works well? I will look into this, though locally (dev environment) it works fine.
I explained it bad, I meant in the sidebar.
anyway after this fix on the dynamic sidebar, the sidebar blocks do not work on our forum :frowning:
I’m even more confused now. The link for the fix you added is for a different plugin, the “Dynamic Sidebar” plugin.
I haven’t tested using the “Dynamic Sidebar” plugin with my Sidebar Blocks plugin, it’s very likely they don’t play nice together. And… you shouldn’t use both. If you need to put only HTML in the sidebar, use the Dynamic Sidebar plugin. If you need the blocks, use only the “Discourse Sidebar Blocks” plugin.
you are right, I haven’t got it right and I thought this plugin works alongside dynamic sidebar plugin.
thanks .
Hi pmusaraj,
I think it will be nice if Dynamic Sidebar can automatically moves the sidebar column down/up when users scroll, and refresh :slight_smile:
Hi @pmusaraj is it possible to customise the css of the sidebar using the discourse customisation panel? I want to have a bit thinner but using the .sidebar selector hasn’t worked for me. thanks
This is a great plugin. Will it be updated for 1.7+? I don’t think it’s currently compatible.
Yeah, it looks like the upgrade to Ember 2.10 broke the plugin. I will look into solutions to fix.
@jgujgu the plugin is now compatible with the current version of Discourse (1.8.0.beta1) following this commit:
https://github.com/pmusaraj/discourse-sidebar-blocks/commit/5e949db074317616596c8f9332cadcb99b764c66
thanks for the report!
Yes, it’s doable. You may want to use the specific selector in your CSS customizations though:
html:not(.mobile-view) .has-sidebar+.sidebar {
    border:1px solid red;
and don’t forget to also update the width of the main column html:not(.mobile-view) .list-container.has-sidebar as well.
A few improvements on the plugin:
Does javascript work in the custom_html field? Having issues trying to get a twitter widget to diplay
